MBP 96 single 8s
  • Tomcandersen
    • 91
    MBP 96 single 8s
    Hi, just started building my new MBP 96 bulletproof.
    Setup will be TP4060 1800kv, etti 220hv and 8s. Hope it will be fast!!
    Paint and decals :-)
    Clear coat..
    If not today, maybe to morrow..
    HPR C5009 twin TP power 4082 2390kv 95mph, Sprit Cat 36 singel Proteus 65mph, Baby SV43 TP power 5850 920kv 12s 70mph
  • Tomcandersen
    • 91
    Just to see.. And of course was the servo mount to high..
    • ls1fst98
      • 905
      man, thats the third one ive seen....i want one now...good looking boat, looking forward to seeing it run.
      i have a 4070 tp 2200kv, im thinking it may have a home.
      • Tomcandersen
        • 91
        Order one, you won't regret it.. ;-)
        • iridebikes247
          • 1669
          That boat looks awesome, definitely will be fast.
          • Tomcandersen
            • 91
            Got the motor mount done :-)
            • Tomcandersen
              • 91
              Some more pictures ;-) small progress, I have been away for some days!!
                Not trying to be a Debbie downer here, but I've noticed a few things:
                That motor is a decent motor, so don't take it the wrong way. It's rated for 50k rpm. It used to be rated higher but they lowered the rpm limit on it, I suspect from excessive failures? At 3.7v per cell on 8s which would be around the voltage it would be under load, you'll be in the neighborhood of 53k rpm. Not a whole lot higher than the rating....but... Say the prop comes out the water and it unloads....that could be in excess of 60k rpm. The shaft on that motor is 5mm. Unless your having them make you an 8mm version (which they will do and I highly recommend) the 5mm version will flex the shaft at high rpm and the rotor will hit the windings. I've experienced this myself with a slightly shorter motor with a 5mm shaft so I know this for a fact. The reason I'm telling you this is because I've done setups like this and with this exactly motor, so I know. You'll only need 7s if your trying to hit 100, 8s will be a gross overkill. I'm not so sure your Esc would be up to the task of that load either. Hey I could be wrong, but I just wanted to point out some things I noticed.
                • Tomcandersen
                  • 91
                  Thanks for heads up..
                  I now I'm pushing it so I will consider 7s at least to see how it runs :-)
                  I had the same setup in a 40" deep V but with a castle 200hv esc and that went fin, all readings from the log was fine but off course it all depends on prop and how it runs.
                  Maybe you are right, time will show ;-) if there is anything else please let me know, I learn every day!!!
