Water jacket and motor problem
  • Viceguy
    • Aug 2014
    • 28
    Hi all, i've just got the motor for my new boat and was planning to use a water jacket i already had. The motor is the "TP Power - 4050-3Y - 2050KV - V1" and the waterjacket are the "TP Power - CJ40L Cooling Cap" . According to the website the jacket should fit the motor but don't, when i connect water to the inlet it leaks in the o-rings. The jacket fit but the o-rings are not tight enough to seal, also the jacket sit very loose on the motor.
    So i'm wondering if i can just replace the o-rings rather than purchase a new waterjacket, and if so wher to buy them and what size rings should i buy?
  • Viceguy
    • Aug 2014
    • 28
    anyone???
    • kevinpratt823
      • Aug 2012
      • 1360
      You can buy a lot of replacement o rings here on ose, but it sounds like it isn't the correct jacket. Maybe the v1 motors are different? Mcmaster-carr sells all kinds of o rings, but without knowing what you have and how far off you are I don't think anybody can tell you what size, you would have to experiment.
      Sent from my SM-G920V using Tapatalk
      My private off road rc track
      • Viceguy
        • Aug 2014
        • 28
        i think i'm off 0,5 - 1 mm on the o-ring hole (inside diameter) Kevin, as it should have been that much smaller without effecting the outer diameter which is perfect.
        • iridebikes247
          • 1528
          Tp changed the size of their can like a year and a half ago by making them shorter but also, narrower by a mm or so.
          I would call TP power usa, they're very helpful and might have the correct cooling can, they're only like 15 bucks.
          • Viceguy
            • Aug 2014
            • 28
            Thanks, but it's not so cheap here in Norway, it will cost me like 30$ to get it here in Norway, thus me trying to get different o-rings instead
            • 785boats
              Wet Track Racing
              • 3169
              The motors are 39.5mm now. Not 40mm.
              Oversize rings can be bought from your local Bearing & Seal supply store for just a few cents. I'm sure there's one near you. Take the motor & can along. They will sort you out with the right size rings.
              • CornelP
                • 745
                Try here... much closer to you:
                • Viceguy
                  • Aug 2014
                  • 28
                  I'm afraid i need to order through the net as i live in the middle of nowhere :D Thanks for getting the correct motor measure, so i guess i should get a o-ring that are 39.5 mm inside and 40.5 mm (or 41.5 mm?) outside diameter - thickness at 1 mm?
                    • 5660
                    Whenever this happens, I never bother to get the "O" ring, I use silicone sealant to seal the whole dang thing from outside. Just the GE Silicone Sealant
                    ( for bathroom or window sealing)---I don't know if you have similar product in Norway. I seal it very neatly and it never give me trouble.
                    Just my $.02!
                    Cheers!
                    • Viceguy
                      • Aug 2014
                      • 28
                      That's actually a great idea tlandauer, i'll keep that in mind as a backup plan. Will call a company that are big on o-rings tomorrow, if they can help me great - if not i'll go for your suggestion.
                      • Viceguy
                        • Aug 2014
                        • 28
                        using silicone as you suggested didn't work tlandauer, it leaks like hell even with that on and it never cured. (after 1 day it was still sticky as hell. Also the dealers of o-rings didn't have anything according to the mesurements i posted previously. So the question now is if i can aircool the motor as i refuse to purchace a new jacket just because the o-rings are wrong. On top of that the dealer here in norway seams to have blacklisted me because they messed up a previous order that got missing in the mail on it's way to me
                        • rayzerdesigns
                          • Dec 2013
                          • 1228
                          I use shoe goo..it seals and dries quickly..remains flexible..i do it to all of my water jackets..never leak..i even did one without an oring
                          • Viceguy
                            • Aug 2014
                            • 28
                            shoe goo ??? never heard about that. Do you have a link to that product so i can see what it liiks like/contain - maybe we have someothing similar here
                            EDIT: i have something called Locktite power glue repair extreme, can that be used?
                              • 5660
                              Very sorry that it didn't work, may I ask you if the silicone is relatively new? They do have a shelf life. This is what i use:
                              http://www.amazon.com/GE-Sealant-Sil...icone+ii+clear
                              or:
                              it should cure, make sure there is no oilly substance on it.
