Delta Force 33 Cyber Storm build log and questions
  • SlickZERO
    • Dec 2013
    • 138
    My Cyber Storm arrived Monday from OSE. Very nice with excellent glass work. The bottom is pretty straight and will require very little work to blue print. I have ordered everything (I think) needed to complete it form advice on the OSE and RC Groups message boards. I will keep you posted as the build goes along. Thanks for the advise.
    Dumas Air Boat OS 25 nitro, Dumas Air Boat Brushless, Midwest Lobster Boat, AQ Lucas Oil Cat, Dumas Hot Shot IV Proboat outboard, Delta Force Cyber Storm 33
  • SlickZERO
    • Dec 2013
    • 138
    I laminated 2 pieces of 1/8” plywood (not the light plywood with the soft center) with the grain at 90 degrees. After proper prep I epoxied it in. The picture is of the jig for a tight fit and let cure vertical. That way any squeeze out won’t pool in the bottom of the V.
    • SlickZERO
      • Dec 2013
      • 138
      Turn fins and trim tabs
      I have looked at several pictures but am unsure of just where to install the turn fins and trim tabs. I have the 68 x 25 x 2 mm turn fins OSE-80062 and the Dual 2.24 x 1.89 x .61 inch trim tabs. Any advise? This is my first mono build.
      • Heath M
        • Mar 2008
        • 806
        This might help
        http://www.radiocontrolinfo.com/rc-b...no-hull-setup/
        Brisbane,QLD, Aussie
        • SlickZERO
          • Dec 2013
          • 138
          Originally posted by Heath M View Post
          Thanks! Looks like good information.
          • 785boats
            Wet Track Racing
            • 3169
            Slick.
            There's a couple of pics at the bottom of this link too that might help.
            • SlickZERO
              • Dec 2013
              • 138
              Slick.
              http://www.rcgroups.com/forums/showt...pper+30&page=3
              Thanks, that is a great diagram. The Cyber Storm is slightly bigger so I can scale the numbers.
              • SlickZERO
                • Dec 2013
                • 138
                Carbon fiber
                I layed down some carbon fiber in the bottom. I noticed it helped stiffen the slight flex in the bottom.
                • SlickZERO
                  • Dec 2013
                  • 138
                  Flooded tube
                  I cut the hole in the transom all the way at the bottom for the flooded tube. I test fit the tube but is not cut to length yet.
                  • SlickZERO
                    • Dec 2013
                    • 138
                    OSE Shaft Tube Seal
                    Since the motor will be sitting near the bottom and the tube will be below the water line has anyone used one of the OSE STS187 Shaft Tube Seals? Good idea or not?
                    http://www.offshoreelectrics.com/pro...d=aero-sts-187
                    • SlickZERO
                      • Dec 2013
                      • 138
                      Battery trays
                      Should I use battery trays spaced slightly off the floor with velco straps or just velcro them to the bottom? I have the Lucas Oil Cat with them velcroed to the floor and haven't had one come loose even on a flip. I see builds done both ways.
                      • SlickZERO
                        • Dec 2013
                        • 138
                        Turn fins
                        Turn fins installed. Used OSE-80062 Medium 68 x 25 x 2 mm. I put them 90 degrees to the bottom and about the middle of the flat spot near the outer edge.
                        • Luck as a Constant
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          From my experience with delta force monos, they like larger turn fins. If it skips and hops in the turns you'll know. Those could be fine on that hull.
                          • SlickZERO
                            • Dec 2013
                            • 138
                            Thanks for the tip. I will adjust them all the way down and if it skips and hops I will get longer ones.
                            • SlickZERO
                              • Dec 2013
                              • 138
                              Trim tabes
                              OSE-80070 Dual 2.24 x 1.89 x .61 tall. Installed the trim tabs at my best guess from pictures. 2 mm above the bottom. I did have to bend them a little more to make 90 degrees. They angled down slightly without touching the adjusting screws. Also the holes in the tabs didn't quite line up with the bracket holes. I clamped them together and ran a drill through them so the screws would go through.
