Painting my Shockwave 55 the primer is creaking!!!
  • ODIE105
    • 44
    OK so I'm trying to paint my hull. I sanded it to get it nice and smooth and so the primer wood stick. but today win i primed it, the primer started creaking and spitting!!! the hull was in the sun but i moved it to the shade to cool for a hour thin i primed it..
  • shua
    • Apr 2015
    • 479
    Did you wipe it down really well with acetone or something beforehand? Also what paint/primer did you use? Some brands may not be compatible.
    • ODIE105
      • 44
      NO i forgot to wipe it with acetone.
      • Luck as a Constant
        Make Total Destroy
        • Mar 2014
        • 1952
        Yeah... Cleaning it is a start.
        What primer?
        • ODIE105
          • 44
          Rust-oleum's sandable primer
          • ODIE105
            • 44
            do i need to sand all the primer of or can a sand it smooth thin use acetone.
            • shua
              • Apr 2015
              • 479
              You will likely find that the acetone will remove the primer if it hasn't had more than a few hours to dry yet. Then you can just wipe off primer and start over.
                Make Total Destroy
                • Mar 2014
                • 1952
                Acetone will probably wipe the primer off lol
                I would lose the primer entirely unless you have repairs that need to be filled.
                Just sand and paint.
                • ODIE105
                  • 44
                  IMG_0041.JPGIMG_0042.JPGIMG_0043.JPGIMG_0044.JPG Ok here we go again. it look's alot better this time. i bite the bullet and got a spray gun and good primer.
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    Nice!
                      • 9481
                      Looking forward to this one !
                      • ODIE105
                        • 44
                        Ok i'm ready to sand the primer but not sure on the grit to use. Do i use a 300 or more and do i wet sand or dry sand?
                        • ODIE105
                          • 44
                          OK I'm going red for the bass coat and lime green for the skulls and flames. I'm cleaning the shead too so i can paint in there c3db4aa6d4c2cbde8dc18bb6dd8afcb1.jpgCC4027.jpgskull with flames.jpgside skull with flames.jpg1111111.jpg
                          • ODIE105
                            • 44
                            ok i got the red on and in 2 or 3 day the green skull/flames will be next.IMG_0053.jpgIMG_0055.jpg
