Another Campell Shovel - part dew
  • egneg
    • 4759
    This is it so far - I think I have enough flotation!
    IMPBA 20481S D-12
  • Heath M
    • Mar 2008
    • 865
    I like the ply sheeting on the hull floor, did you make that or does it now come with the kit??
    Heath
    Brisbane,QLD, Aussie
    • egneg
      • 4759
      Thanks - I used 3/32 plywood and a 3/4 forstner bit for the holes. If you look at the center hole in the front it's off a bit. I measured wrong but it won't be seen once the top is on.
      IMPBA 20481S D-12
      • egneg
        • 4759
        I have made a bit of progress on this hull - here are some pics.
        IMPBA 20481S D-12
        • egneg
          • 4759
          The Poly-flex has been sanded around the stuffing tube and ride pads. I have also made the hull penetrations and fitted the hardware. The next step is to beef up the motor mount a bit, seal all the wood parts, and add the flotation.
          IMPBA 20481S D-12
          • Heath M
            • Mar 2008
            • 865
            Looking good mate. Good idea to beef up the motor mount too,the motor screws dig into the wood pretty bad..Don't forget to seal all the the bracing :)
            Another idea is once the deck is on cut out the center bulk head, it's makes it easier to fit the batteries..
            Heath
            • egneg
              • 4759
              Thanks for the advice ... if you look at the first post I added some carbon fiber rod just in front of the center chunk of wood (and also at the front) so I would have that option.
              IMPBA 20481S D-12
              • egneg
                • 4759
                I have a question about the pink foam used for the flotation.
                1. What is used to glue it down? I tried shoe goo and that ate the foam.
                2. Do you sand it to shape or use a razor blade?
                IMPBA 20481S D-12
                • J Solinger
                  • Apr 2008
                  • 197
                  If I need to glue the foam down I use 5 minute epoxy. A razor blade or thin sharp knife works well. A sharp serrated bread knife is good too.
                  Joe Solinger
                  • egneg
                    • 4759
                    Thanks for the information - I will try the epoxy.
                    IMPBA 20481S D-12
                    • egneg
                      • 4759
                      I have the flotaion in place and have started to work on the deck.
                      IMPBA 20481S D-12
                      • Ocean Racer
                        • 511
                        are you going to have the outlet through the exhaust?
                        Failure is the First step to SUCCESS
                        • egneg
                          • 4759
                          I had planned on a side outlet and already have the penetration/hardware for it. The exhaust could be used but will be plugged from the inside.
                          IMPBA 20481S D-12
                          • Ocean Racer
                            • 511
                            o well but that would be cool
                            • Sneasle
                              • 202
                              looking good.
                              Where did you get the hull/kit?
