sealing wood boat hull
  • okieman98
    • Jan 2014
    • 229
    i was getting ready to seal a wood hull with z poxy but wanted to ask, can u use epoxy paint instead maybe. just a though killing 2 birds with one stone so to speak. or do i need to seal first then paint
    thanks all
    1 motley crew- under construction 2x shock wave 26-2 x surge crushers - 1 30' mono
  • grsboats
    • 1011
    Yes I would recommend you first seal carefully your hull,sometimes you need to aplly more than once epoxy sealant, wet sand it with light paper then apply P.U.(bi component ) primer....then finally go to painting....this just me....this way I have boats built fifteen years ago looking brand new.Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • TheShaddix
      • Sep 2013
      • 759
      what if you want to have just a clear coat to show the wood grain, would epoxy resin be enough as the main and final coat? Or does it still need some kind of a clear coat sprayed onto it later?
      • okieman98
        • Jan 2014
        • 229
        ok thanks what i was thinking but wanted to make sure before i did anything,
        • Chilli
          • 3204
          You wont need to clear over it unless you sand down to bare wood. It will probably take a few coats to get a nice smooth finish.
          I use this stuff. Expensive but it works great with no scraping and very little sanding required. It's the viscosity of diesel fuel. First coat soaks into the wood. An extra coat or two will fill in the grain and easily sands to a nice smooth finish. I usually apply the last coat with a lint-less cloth. Makes the wood stronger without adding allot of weight.
          PES is an excellent wood preservation, rot repair and restoration product. It can be used on any wood in boats, in and around homes, Log Homes and RV's.
          Mike Chirillo
          www.capitolrcmodelboats.com
            http://www.rotdoctor.com/products/cpes.html
            This is great info.
            Question: I have a prebuild hyfro hull ML GP400 that the builder had applied expoxy sealing, it is just a rough coat---meant to be sanded down and painted. I want to retain the wood appearance and also prefer the epoxy you linked over automotive clear as the final coat, I can sand smooth the epoxy that is already on it but I don't see how I can remove it completely and expose the wood grain, can I still use this stuff , and will it adhere to the epoxy that is on?
            Thanks!
            • lonewolf
              • Jul 2007
              • 713
              If possible do a small test to check compatability to remove old epoxy lots of elbow and higher grit sandpaper 400-600 or higher once getting close... if the skin is ply use caution extremely easy to sand thru a layer and well appearance is lost... maybe block sand for bulk then carefully hand sand remaining areas....I hope this helps... Best regards Lonewolf..................................Ive messed up a few times and learned a bit...
              • lonewolf
                • Jul 2007
                • 713
                If possible do a small test to check compatability. To remove old epoxy lots of elbow and higher grit sandpaper 400-600 or higher once getting close... if the skin is ply use caution extremely easy to sand thru a layer and well appearance is lost... maybe block sand for bulk then carefully hand sand remaining areas....I hope this helps... Best regards Lonewolf..................................Ive messed up a few times and learned a bit...
                Ive started using a foam liner on my blocks to lesson the hits on the hi spots... example a sheetrock sanding block however far higher grit... just wrap a proppper grit paper around foam block
                  Thanks for the advice!! :-)
                  Sent from my D6708 using Tapatalk
