Well guys, the saw dust has started to fly. I'm not sure how long this build will take as the fall semester has started and my grades come first (I have to maintain my 4.0).
I have two sets of stringers cut out so far (as I will be building two boats at once).
Specs
length: approximately 16"
Beam: approximately 6"
power: twin 3550kv outrunners on 6s 1450 mah (3s per motor)
Motor Dimensions (Diameter x Length) 27.9mm x 37.6mm
Shaft Dimensions (Diameter x Length) 3.14mm x 15mm
esc: mystery 30a
servo: tower-pro SG90
flex shaft .098
hardware will most likely be homegrown (since the budget is tight)
I have a new cooling idea
(to be announced later)
(the second hull will most likely be single power, as I know the twin is going to be absolutely ridiculous)
more to come
similar boat builds:
http://forums.offshoreelectrics.com/...ead.php?t=4563
http://forums.offshoreelectrics.com/...ead.php?t=3413
http://forums.offshoreelectrics.com/...ead.php?t=4723
Specs
esc: mystery 30a
flex shaft .098
(to be announced later)(the second hull will most likely be single power, as I know the twin is going to be absolutely ridiculous)
more to come
