29" Skunk works deep V
  • Mich. Maniac
    • 1456
    I am going to start building on this one as well. I think I have the motor selected just waiting for stock. This will be my first build with Neu motor. I will be running 4S1P to a 1515 1Y (2200KV) and will start with a X642 prop. This hull will be running wire drive as well. I would like to get everything together to build before I start and just need esc. I was thinking CC240 but am wondering if anyone would know if a CChydra 120 would be safe. I have no clue on how to use FE calc.
    Thanks and I will take pictures as soon as all the goodies start rolling in!
  • tth
    • Apr 2008
    • 1600
    F E Calc Will Not Give Good Estimates With 4 Or 6 Pole Motors. A Few People I Have Seen Run The 1515 1y With Good Results. Just Prop Small And Check Temps As You Already Know I'm Sure.
    EDIT: JUST FOR THE HECK OF IT I RAN YOUR SETUP INQUIRY THROUGH FE CALC AND IT TOPS OUT AT 155 AMPS WITH TOP SPEED OF 49 MPH............GO WITH THE 240!!!!
    • Scott T
      • 625
      I've run that set up in a DF33 with a Barra 125 with no problems. However, I think the B125 is closer to a H240 than a H120, so it might be worth the extra bucks to go for the 240.
      I actually went back to an X442, it seemed to suit the boat better. Next stop will be an M445.
      Scott Tapsall
      Pine Rivers Model Powerboat Club - Facebook Page
      My Gallery
      • ED66677
        • 1300
        Mich. I've seen one running with a 9XL under 4S CC120, 51mph GPS!
        The Neu will take you te hell
        Emmanuel
        • electric
          • 1973
          I am planning to try out an 8xl with a cc120HV 14.4 volts on a Delta 33 knock off. Sounds like the x442 might be the way to go? What kind of speed should I expect?
          • tylerm
            • 310
            Heres my build of the same hull, using a 9XL(feigao) and 4s1p for our clubs restricted class.
            Tyler.
            • ED66677
              • 1300
              Tyler, have you done any vids of your boat in action?
              Emmanuel
              • Mich. Maniac
                • 1456
                Excellent deal. Thanks for the input gents. I think I will still go with the Neu 1515 and hydra 240. I will have a great deal invested but If I ever go for something else a bit larger like a 33", then I should have what I need. I should have the hardware and motor in hopefully about a week. I will try to order motor through OSE. Most hardware was purchased through ebay.
                • tth
                  • Apr 2008
                  • 1600
                  It's A Good Idea To Get Equipment That Can Be Swapped Between Boats.
                  • tylerm
                    • 310
                    Nope, was gonna test last weekend but we had a bad storm. Hoping for good weather this weekend so i can have a test and hopefully get a little vid on my phone, won't be nearly as good as your vids Ed
                    Tyler.
                    • ED66677
                      • 1300
                      cool!
                      Emmanuel
                      • Mich. Maniac
                        • 1456
                        Im about to get strut and wondering what size wire to use for this kinda power, 3/16 prop shaft I know but will also be running 4S neu 1515 (2200kv)? How thick of wire?
                        • Mich. Maniac
                          • 1456
                          Oh, and what size tube to use with that size wire? And do I use Teflon with it? One more,,, Does the systems OSE sells come with tube and or teflon?
                          • tylerm
                            • 310
                            Unless you going to mount the motor right up front, and place it a bit higher than usual, i wouldn't personally use a wire drive in this mono. I have used wire in a mono before and when you have to use a sudden bend, instead of a gradual bend like you can get in a cat or hydro you get a great amount of drag in the system
                            In my build i used .150 linerless cable, and i would do that again if it were me, either that or go up to .187 cable.
                            Hope this helps,
                            Tyler.
                            • tylerm
                              • 310
                              Ran my boat today, went really well but dad didnt use the zoom on the camera so the vids useless. The boat performs really well, i cant wait to get some decent gps readings.
                              Just an FYI, i had to raise the strut alot to get this to run loose, so keep that in mind.
                              Tyler.
