Hpr 150
  • hanspeter
    • Mar 2010
    • 114
    Hpr 150
    hello
    here a small build process from my HPR 150. i will make the old good victory.
    hull is bullet proof ultimate.
    greetz hanspeter
  • hanspeter
    • Mar 2010
    • 114
    Mounts from the waterp pickups drives rudder
    • hanspeter
      • Mar 2010
      • 114
      drives an rudder
      • ls1fst98
        • 905
        Very nice!!
        • Fella1340
          • May 2013
          • 1025
          You never disappoint! Really looking forward to seeing what happens here. I'm curious about the drill and solid rod going into the drives, I had written a few guesses from lapping the bushings(if bushings are used), seating and running in bearnings and also it being a special tool for drilling into the hull for stuffing tube arrangement. None seemed to quite fit. What's going on there:-)!
          • hanspeter
            • Mar 2010
            • 114
            hi
            this is a Special tool for Drilling the hole for the Flex and shaft tube. the drive is mountet in the optimal Position.
            so i have the propshaft and the Flex 100% in the centrum
            greetz hanspeter
            • Fella1340
              • May 2013
              • 1025
              Very good idea, takes any guess work out of things that's for sure. That's the type of stuff I love seeing in the high end builds. It really helps us newer builders become better. Thanks
              • TheShaddix
                • Sep 2013
                • 759
                How does this tool work? Seems like a great idea to make that perfect angle from drive to stuffing tube entry point.
                • flraptor07
                  • Aug 2013
                  • 2451
                  It's probably a long drill bit.
                  • TheShaddix
                    • Sep 2013
                    • 759
                    maybe some kind of a tube that holds a drill bit? Hanspeter can shine a light on this mystery!
                    • Fella1340
                      • May 2013
                      • 1025
                      It would be a piece of precision ground shafting or tube the same size as the inside diameter of the bearings with a drill machined to fit the end. Nothing fancy but a really great idea. Every little bit helps getting things to run as true as possible.
                      • hanspeter
                        • Mar 2010
                        • 114
                        hello
                        thank you. the next step is the mounting from the engines. i have make a Special
                        Support,and build this out from the boat. so i can make this 100% exact.
                        greetz hanspeter
                          Originally posted by hanspeter View Post
                          hello
                          greetz hanspeter
                          Ahha, the flexible tubing for the stuffing tube. That is what I have been watching for. Where did you find that Hanspeter? I have been watching for old oil cans but that looks new. I have had thoughts of it for my HPR 115
                          Shawn
