Cozy F1 Tunnel - wood build
  • Dirk Jan
    • 167
    Hi fellow rc boat enthusiasts, this is my first post here, so I introduce myself shortly: my name is Dirk Jan, I'm from the Netherlands and I am building rc boats for many years now. I especially like to build wooden boats.
    I read along for a while now and I think this forum is great. You can find a lot of knowledge and nice boats here.
    Time for me to share my latest project with you. I designed my own F1 Tunnel hull, called Cozy F1 Tunnel. It's 23.6 inches long and it will get the following setup:
    - Hobbyking/TFL outboard
    - 3S 3Ah lipo Turnigy
    - 60A Marine esc
    - total weight: 3,3 lbs
    The cowl I will make myself from glass fabric and epoxy, using a mold.
    I designed the hull in Pro/Engineer CAD software:
    I make all frames myself by using a hand saw, no laser kit here
  • Dirk Jan
    • 167
    Next couple of photos:
    And starting with the tunnel itself:
    • Dirk Jan
      • 167
      Build post #3:
      Test fit the sponsons to the tunnel. It starts to look like it! :)
      Reinforcing the tunnel with some ribs and adding some high density foam for flotation:
      So far for now. More updates will follow soon!
      • Dirk Jan
        • 167
        Build post #4:
        Finishing the tunnel and laminating the hull with 50 grams glass fabric.
        • Dirk Jan
          • 167
          Build post #5
          Some more photos from the hull with the sponsons attached and starting to work on the cowl mold.
          Servo / receiver plate:
          Modifying the back of the tunnel a bit for more room for the steering links:
          And the hull so far. The servo plate is not glued yet. It will move more backwwards finally.
          • grsboats
            • 972
            Very nice building...looking forward to see some action videos.Thanks Gill
            GO FAST AND TURN RIGHT !
            www.grsboats.com.br
            • Dirk Jan
              • 167
              Thanks Gill! Here's the next build post:
              Making the cowl mold:
              Power plugs from esc to the motor:
              The hull with electronics installed:
              • ron1950
                • 3024
                wow ...always impressed with scratch built boats etc...great job
                • Dirk Jan
                  • 167
                  The mold is finished:
                  Applying 4 layers of 110 grams/m^2 glass fabric over the mold to make the cowl:
                  The cowl came out good:
                  Applied some base coat:
                  And finished except for the paint!
                  It runs very well. The hull runs nicely above the water and turns very sharp. Top speed is 31.5mph. I'm still experimenting a bit with the setup to improve the performance. But so far I'm happy!
                  Here's a video:
                  If anybody is interested in the plans (PDF) send me a message. I share the plans for free.
                  • NativePaul
                    Greased Weasel
                    • 2764
                    Beautiful!
                    • studioRS
                      • Jan 2009
                      • 111
                      Beautifully built! Thank you for documenting your F1 build. I am very interested in building one myself, PM sent. Thank you!
                      Cheers, Thompson
                      Cheers, Thompson
                      1/10 1954 Breathless U-22, Tahoe Yacht Club | 1/16 1958 Dumas Thiftway Too, built in '92
                      • Dirk Jan
                        • 167
                        Thanks! :) You got the plans in your mail box.
                        • studioRS
                          • Jan 2009
                          • 111
                          Thank you, Danke
                          Cheers, Thompson
                          • seehuusen
                            • Apr 2012
                            • 96
                            great work mate! very cool boat to run too by the looks of your video :)
                            • Dirk Jan
                              • 167
                              Thanks Seehusen :) It is a very nice hull to run. I like the outboard setup and the hull almost entirely out of the water at full speed.
