The Spartan project
  • TheShaddix
    • Sep 2013
    • 759
    The Spartan project
    Hi all,
    I "briefly" built this spartan a while ago, but sold it to a friend as I grew quite tired of it and wanted to work on other (better) boats, but since it was collecting dust in his garage I felt a bit nostalgic and decided to buy it back. I also felt I could have done a much better job on it but due to lack of skill I just spray-painted the hull black, installed some random hardware, and called it a day... So I just started tearing out everything that was in there, all the plastic junk and mounts. My plan is to get it to an empty, clean hull, and do a full CF inlay (12k carbon cloth) and power it up with a leopard 56mm motor, a SF 300A, and 8S revo 70c batteries (2x4s in series). Not looking for any crazy speeds, this will be a beach boat. I will post new pictures as they come. And btw, I'm still building my genesis, I have not given up. This is just one of those unplanned projects that came along.
    And also was given this beauty to resurrect! Not sure why I agreed to work on this one, but seemed doable. This is the result of a seaking 180a v3 blowing up due to using the wrong motor with it on 6s.
    I will post my progress on this one as well as the spartan in the same thread as they both seem a bit hopeless at the moment.
  • Roy Van De Sande
    • Nov 2013
    • 143
    I love to give used boats a new life :) The spartan looks really good already! The seaking 180A V3 isn't a very good esc. The V2 was but the V3 just isn't.
    Keep up the good work! I will follow your thread
    • TheShaddix
      • Sep 2013
      • 759
      Some updates finally. So I stripped everything out of the boat including the secondary plastic layer. Then I did an inlay. Also decided to paint the hatch, the two blue metallic stripes plus clear coat over the whole thing, reinforced with cf.
        looks good! what epoxy did you use to bond to the plastic?
        • iop65
          • Mar 2013
          • 367
          i was told that epoxy doesn't stick very well on abs ,never tried it myself ,so want to know that too
          • TheShaddix
            • Sep 2013
            • 759
            Regular epoxy, it sticks to plastic, not as good as to carbon or fiberglass because the plastic is so flexibile, but it still works as long as it's sanded well. I used 12k cloth which is about 4 layers of normal 3k, so it's very rigid once cured and doesn't allow plastic to flex as much causing it to separate. But for sure, epoxying to plastic sucks! This is the worst boat i have worked on in every possible way, but it's something I wanted to do ever since I sold my first spartan (the first boat that got me into this hobby) which was nothing but a headache. I had to see if it could be turned into a decent boat. So far I'm not completely convinced.
              Sounds like the same thing I'm doing with my shockwave. First boat I owned. I desperately wanted 40-45mph out of it. I'm at 53.8mph with this one. Lol. 26" plastic boat.
              What are you looking to get out of it? That esc seems little complete and utter overkill lmao! Esc worth more than the boat. Why not a smaller, light seaking 180? Just wondering.... I'm sure you already had that esc is the main reason... But still... :)
              • TheShaddix
                • Sep 2013
                • 759
                Looking to get 60-70 mph out of this one. But I won't be too upset if I hit 55 or something like that. I'm building it for the beach to jump waves, hence all the reinforcement. Since last weekend when I took my HPR there I realized that flat water saw runs are getting a bit old for me. There is just something awesome about seeing a 45 inch heavy boat jump 3+ feet in the air and land it.
                I'm running 8s so I can't use the seaking. And a lot of people have been blowing up their 180a v3's lately in their monos running 6s, more likely than not it's a user mistake and abuse, but i just wanted to try this swordfish esc, been eyeing it for a while. This one is from Keith, he used it once so I got a good deal on it, hence no stickers which I like. And if you think about it, people running those MGM esc's in their MHZ and HPR hulls... Those two esc's cost around 1k total while the hull you can get for 500-600 bucks, carbon kevlar... So it's not really about esc's costing more, it's about the overall build result and if it's worth the money. In this case with the spartan, I don't think it's worth it at all, but I really didn't want to throw the hull away. I have a sniper 45" mono sitting here which I was intending to use these components for, but then, unexpectedly, bought my spartan back. So I feel like this is definitely a project. Crappiest hull in the world being turned into a less crappy hull. We'll see what happens!
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  That Spartan is gonna be a beast with that motor
                  Is the other a Pursuit?
                  • TheShaddix
                    • Sep 2013
                    • 759
                    yup, a pursuit! That one is such a mess, I don't even know how to get started on clearing it all out.
                    • FORT-26
                      • Apr 2014
                      • 239
                      56mm.....
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        I assume you realize that in order to get that power to the water you will need a large prop...................problem is the Spartan will only take so much diameter before it protests due to the narrow hull. You need to find a middle zone between diameter and pitch..............maybe somehwere in the x648.........s235 range.
                        • TheShaddix
                          • Sep 2013
                          • 759
                          My plan is to run a modified x457 prop cut down to 47mm. I'll just go from there. Right now I have no idea how this setup is going to behave in this hull. Another thing to consider is the weight of it. I think it should handle much better. I've already run it with a 4092 leopard on 6s and, although it wasn't all that fast, it was planted for sure. Now it has twice that weight. We'll see what happens.
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            If you havent already cut down the prop try it at 50mm first, you can always reduce size............not increase obviously
                              Here's my opinion (but what do I know?) your going to be turning close to 41k rpm (all estimated and free rpm based on 3.8v per cell) on 8s with that motor. My cat with an 1800kv motor (less to tho so may not turn as many loaded rpm as yours) on 6s and an m645 prop was running mid to high 70's on 6s. Now.....I use that as a bench mark when trying to guess on a setup because it's tried and true. Given yours is a mono being a little less efficient and slightly larger, we can assume it won't be that fast. But, if I had to guess, on 8s with an m645 prop you'd be in the 60 to 65mph range assuming you keep the chine walk under control. What's my point? In my humble opinion, your choosing too much prop for your rpm and hull. An m645 prop has become my favorite because it has all the potential you'd need, plus I know its not going to prop walk on you. I run one on my 26" shockwave all the way up to my 37" Daytona and it doesn't prop walk on the 26" plastic boat. The shockwave setup is turning 36k rpm and running low 50's and it's not trimmed right yet. Just trying to give you some ideas to help you choose a prop. We tried 52mm to 48mm props on my buddies Spartan and it didn't like it. My rule of thumb is: high rpm (close to 40k and over), small prop, decent pitch. Low rpm, high tq.... Big prop, as long as the hull isn't narrow. It's a balance act. If you have a narrow hull, you've got to figure a way to make it not prop walk and my solution has been higher rpm with a smaller prop. Just trying to help.
