New build: Delta Force 26
  • mtgoat
    • Apr 2008
    • 103
    Here's my new Delta Force 26.
    The first pic shows the epoxy drying from the extra layer of fiberglass I laid on the bottom.
    The second pic shows some of the hardware installed. Next are the stringers.
    I plan on running 3s2p. I haven't decided on the motor yet. I'm thinking 9L or 10L. Suggestions are welcome.
  • Mich. Maniac
    • 1456
    Nice clean job. glad you are sharing pics. how do you plan on securing stringers and what determines the width apart?
    • mtgoat
      • Apr 2008
      • 103
      I'll attach the stringers with epoxy and Fiberglass. The width will be such thatthis motor mount will fit between them.
      • mtgoat
        • Apr 2008
        • 103
        Work has progressed quite a bit. I'll get it wet today if weather allows.
        • ace028
          • Aug 2007
          • 986
          Looks nice, take some pics and vids.
          Twin power =
          • mtgoat
            • Apr 2008
            • 103
            Okay, I just got back from the pond.
            Verdict: This boat is cool!
            It's very stable and could use boat-loads more power. I knew the motor I was using (feigao 540 16S) wouldn't be enough.
            • Heath M
              • Mar 2008
              • 865
              i ran the one i had on a 7L and 3s 1p and it was ballistic, handled great too
              Heath
              Brisbane,QLD, Aussie
              • mtgoat
                • Apr 2008
                • 103
                I just ordered a 9L. I'm hoping for a much better result.
                Dave
                • j.m.
                  • Jul 2008
                  • 847
                  you should be able to get it to run like this:
                  • Jimmy Sterling
                    • Apr 2008
                    • 417
                    Very neat set up, looks great !
                    Come to the FASST side
                    • mtgoat
                      • Apr 2008
                      • 103
                      Thanks! I just got back from the pond. I'm now running the 9L with 3s2p. Wow! I did a run with an x432 and another with the x435. No overheating. Very stable. I may try the x632 next time. I have no way of knowing how fast, but it's faster than a well-tuned SV running 5s. I'd meant to get video, but forgot the camera. Next time.
                      Dave
                      • Mich. Maniac
                        • 1456
                        How does the way you have the motor mount/ mounted to your stringers seem? Is it just epoxied in there or secured with bolts? I was thinking of just bolting the alum. part right to stringers via adjustment screws rather than the c/f plates. Would that work ok? Thanks a bunch.
                        • mtgoat
                          • Apr 2008
                          • 103
                          Actually, the stringers are attached to the hull with silicone. After that has dried, I sprayed the area where the motor mount was to go with silicone lubricant (which dries instantly), and then siliconed the motor mount in place. I did it this way in case I wanted to re-locate the motor mount at a later time.
                          You're probably thinking it will come loose, but it's in there solid. It can be removed, though, with some effort.
                          On this particular hull, which has a very low profile, tall stringers would have been in the way of the batteries. They probably stiffen the hull a little bit, but they are mainly there to mount stuff on.
                          As long as you have enough room, I think your idea of mounting the aluminum plate directly to the stringers is an excellent one.
                          • mtgoat
                            • Apr 2008
                            • 103
                            Video
                            Here is video my buddy, Ron shot today. The boat is running a 9L, with an x632 and (2) 3s 25C 1800 mAh lipos in parallel.
                            Dave.
                            • HappyOne
                              • Jul 2008
                              • 185
                              Very nice
                              Thanks for sharing.
                              Grand River Marine Modellers, el Presidente
                              IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro Tunnels
