Project HPR 233
  • mudl
    • 196
    #61
    • mudl
      • 196
      #62
      and the last two pictures
      • grsboats
        • 1011
        #63
        I'm curious to see the performance of theses big outrunners...btw nice and clean build..congrats.Gill
        GO FAST AND TURN RIGHT !
        www.grsboats.com.br
        • mudl
          • 196
          #64
          Hi Guys
          here some news of the HPR 233
          Yesterday it was maiden run.
          I made only some short runs,because i used only 12s1p pro motor
          First run with 74 mm props with1,25 pitch
          second with ABC 2916-15-50 (74mm 1,6 Pitch)
          and the third with Propshop 8015/2
          bye
          mudl
          • grsboats
            • 1011
            #65
            Nice Mudl even in low voltage.thanks Gill
            www.grsboats.com.br
            • Fella1340
              • May 2013
              • 1025
              #66
              Looks great on the water, keep bringing the updates!
              • mudl
                • 196
                #67
                Hi Guys
                here some updates of the HPR 233 Torqstar.
                After several test runs i decide to change the escs.
                With the mgm's i had the problem that they only can run 19000 rpm with the Lehner Torqstar.
                At 19000 rpm they cut off.
                I made several tests with 14s and 12s lipos.Max was only 19000 rpm.
                But i want to get more rpms because i don't want to drive bigger Props as 80mm and want reduce the torque on the Flexdrives and on the clutch.
                The new escs are two brand new Schulze 40334
                I hope that they will better work with the Torqstars.
                I installed 2 plates left and right in the boat where the escs are fixed with screws.
                The Motors got new cabels and new Motor couplers(the normal couplers are not strong enough)
                new tests are outstanding
                here some pictures
                regards
                mudl
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  #68
                  That's very wired, I think the MGM will support 250k rpm on 2 poles so the motors would have to be around 22 poles to reach a max of 20k? Any settings on the controller that may have been overlooked? Either way, very cool build!!
                  Are those brass/steel LMT couplers?.
                  • mudl
                    • 196
                    #69
                    Hi
                    i test several settings on the esc.Nothing helps.
                    The couplers are made by lehner
                    • RaceMechaniX
                      • 3024
                      #70
                      Hello Mudl,
                      I know this is an old thread, but what settings did you run with the MGM for the Torqstar motor?
                      -Tyler
                      Tyler Garrard
                      NAMBA 639/IMPBA 20525
                      T-Hydro @ 142.94mph former WR
