New Chief Canard by DaVette Boats
  • 785boats
    Wet Track Racing
    • 3423
    #31
    Dana.
    Really great results for all your efforts.
    In your redesigning, have you thought about the sponson depth of the starboard sponson.
    My Starfighter Canard (and many others) has that sponson 10mm deeper than the port sponson. It makes the turns so much faster.
    Just a thought.
    • Dana W
      • Mar 2012
      • 35
      #32
      10mm? Hmmm I'll keep that in mind, there's still time to do that . Thanks for your feedback.
      Dana
      • Dana W
        • Mar 2012
        • 35
        #33
        New Chief Canard
        The new hatch is ready to mold.
        • 785boats
          Wet Track Racing
          • 3423
          #34
          Dana
          My boat is only 37" long, so at 46-1/2" long, yours might need to be a little bit deeper.
          You could simply make a thick ride pad, & use double sided tape to hold it on for testing first. Just to see if it makes a difference before you go hacking into the original sponson.
          • Dana W
            • Mar 2012
            • 35
            #35
            The new design is only 43" long now . I'll probably leave the sponsons like they are. I figure if people want to add material to the right sponson it would be easier to add then to remove.
            Dana
            DaVette Boats
            • Dana W
              • Mar 2012
              • 35
              #36
              New Chief Canard
              The molds are now done.
              • Dana W
                • Mar 2012
                • 35
                #37
                New Chief Canard
                Ready to set up
                • Dana W
                  • Mar 2012
                  • 35
                  #38
                  I tested the canard on Saturday and it had great results. It turned amazingly fast and had great speed but I noticed the front pad was riding slightly wet even after giving the prop 1/4" positive angle up. I added a small wing up front instead of adding material under the front pad. That helped a lot. At full throttle the front pad is off the water. Here is a short video of the first run before the added front wing.
                  • Darin Jordan
                    • 9446
                    #39
                    What is the Size of this hull again??
                    Looks like a lot of fun.
                    What prop are you running on it?
                    Darin E. Jordan - Renton, WA
                      #40
                      It's 43" long. "Typical gas prop"
                      • Dana W
                        • Mar 2012
                        • 35
                        #41
                        I'm running a 472 prop right now but will be trying a 572 next.
                        • Darin Jordan
                          • 9446
                          #42
                          If it's driving the nose down, as you've mentioned and as the video shows, you may want to look into the ABC 17-degree or other high-rake props. They have considerably less lift and will really lighten up the nose.
                          72mm ~= 2.8", and if you are leaning towards an X572, that's 1.5 Pitch Ratio, so something like an ABC 2814-16-60(2) CLL, etc., might be interesting... Something worth looking into.
                          • Darin Jordan
                            • 9446
                            #43
                            For what it's worth, on my Cheetah, it was almost undrivable do to the front end running wet regardless of how I adjusted the strut. Swapped to a pair of ABC 1715-17-45(2) props and it ran like it should. Was ballistic.
                            • Dana W
                              • Mar 2012
                              • 35
                              #44
                              Thanks Darin I'll look into that.
                              • Dana W
                                • Mar 2012
                                • 35
                                #45
                                It was a CG issue. I moved the engine back 1" and put my CG at 12 1/2" forward of the transom and it runs great. Very fast and handles the corners like it's on rails.
                                Dana
