My First Fe Build up. A TFL Cheetah twin....
  • Mad Racer
    • Nov 2013
    • 140
    Well for 2015 racing season I will be joining the Fighter Cat / Cheetah boys in 6S.
    I decided on this build about 6 months ago and decided to try my hand at building a FE boat. It was no question in my mind that it will be a twin but that's all I knew. I wanted this Cat to handle trhe rough windy oval course of our Lakeside club the spec's of the build changed no less then 3 times . So I have left over rudders, Flex shafts, Stingers and struts
    The hull was reinforced with fiberglass epoxy up the front and a alloy rear transom plate was fabricated up along with the strut plates.
    I wanted to paint this hull so a two tone green paint scheme was the plan with the hatch being a different tone to the hull. I used acrylic spray paint with a good primer and countless clear coats. The windshield I made out of tracing paper first then transferred it on to some black vinyl with a red trim. Custom Mad Racer & Cheetah decals were made up by my partner using a Roland Stika plotter..
    I'm aware that the placement of the batteries is not what most do but this is one area I looked long and hard in adjust ability of weight for rough conditions at speed. Twin Seaking 180 ESC ver 3 got the nod to sit in each sponsor to keep the COG low and since they are waterproof it was not a concern. Two Turnigy's Aquastar 3660 1460KV motors were mounted on TFL adj motor mounts and placed a little forward then most twin set up's . Lots of mock ups were done to keep the COG at 30%..
    2 beautifully machined adjustable length struts were purchased after looking at flraptor07 set up ( Thanks Chris for your help). They had to be modded a little but all went well with just enough room. A set of machined CNC 4814 props were bolted up for initial testing ( Thanks to Paul on his recommendation on these props)
    To keep with the paint theme a red alloy servo tray, and accessories were added in the build.
    Well so how does it go. It's had 3 runs at 3 different lakes and it screams. Hull sits really nice and corners quite hard. So far no adjustments have been made as I'm so happy BUT I hope it will go well at Lakeside. Servo seems a little notchy and will look into that before it's next run.
    Painting the hull ..
    Mock up stage of components
    My partner doing the Decals up.
    More pic;s to come.
    A big thank you to Chris, Paul, Ray and Trevor.
  • Mad Racer
    • Nov 2013
    • 140
    More Pic's
    Working with the Roland Stika set up
      Looks fabulous! Subscribed!
      • 785boats
        Wet Track Racing
        • 3423
        For a first full build, you've done a great job Mark. Clean & clinical.
        It was riding nice today up at Sippy Downs. Certainly a contender for next year.
        Well done.
        • Mad Racer
          • Nov 2013
          • 140
          Thanks Paul & tlandauer
          Your advice has always been spot on.
          Some more pic's
          • Mad Racer
            • Nov 2013
            • 140
            Wow Paul,
            All done & dusted at the QLD Titles
            Your Cat has been unstoppable for race wins. You build awesome race boats and scalers as well. To be able to race with you neck to neck in the 2nd last heat with the lead constantly changing every corner was without doubt the best racing I have ever done in boating since I started in FE boats.
            My Cheetah has been dodged with handling problems being my first FE build so I was even hesitant to enter her in the States. A small set up change was performed the week before and it now corners half alright but can't hold you off all the time. It's just the sheer top end that I had over you ( being a twin) so it was very much a sea saw race. In fact a few competitor's told me on the day that it's a SAW Cat LOL,
            Anyway I must say Thank you to You, Trev, Ray, & my pit man Warren For the 1,st Title that I have ever won, Always have got 2nd & 3rd's all my life in r/c so it's a nice change.
            • 785boats
              Wet Track Racing
              • 3423
              It's been a pleasure helping you get your boats sorted Mark.
              Thanks for the great racing. Both you & all the other guys.
              It was such a fun 3 days.
              Congratulations on the Trophy.
                • 9481
                Awesome job man !
