H&M Intruder twin build
    So I had asked some questions a while back, this is on my mind for a twin build for sometime. Joel ( ROCSTAR) did a fabulous job for CF inlay ( never attempt to do a job when there are professionals around to help was my thinking, so i sent the hull to him)
    8F5E4BE4-1CE3-4D41-A718-FB0C34531A6C_zpsyjssgwey.jpg4A82D212-7BF8-4268-9A4D-B07F7916510E_zps5wuasbai.jpg
    Prior to sending him the hull, I made transom doublers for the main transom and the sponson transoms.
    I have some questions regarding the position for the stingers. It is a rather small real estate in the back and it's not absolutely flat, the picture shows a "sweet spot", is this OK? I know that in powerful twin cats sometimes if the stingers are mounted too low, there might be too much lift and also unloading props may be an issue, but this is a small hull and I am not setting it up for SAW.
    Please take a look and give me some feed back. THANKS in advance!!
    • olwarbirds
      Magic Smoke Wizard
      • Oct 2012
      • 1194
      Tim, I am no help far as where the sweet spot is on this hull as I am trying to learn about building a fast twin myself. It sure is a nice looking hull. I am a big fan of H&M hulls and do wish we had a good North American supplier of them. Good luck on this build and I will be tuned in brother... Happy Holidays... DJ
        I know we discussed this Tim but if you can get them inward a bit it would be nice. The height looks good.
          Thank you, I am hoping at the very least this would turn out to be a good ''practice run". I regret to try my untrained hands on a H&M hull, but I like the challenge this particular hull presents.
          Shawn, yes, and i remembered your advice, thanks again. I drilled the holes and the issue is if I move them anymore inward, there is a bump and will cause the stingers to have a pronounced "toe-in" viewing from the back.
          Anyway, I did my singer per your suggestion and now i got two nice Hughey .150 cables for the build!
            So as slow as it is, I am using easy materials to get everything close to the final version.
            As i posted somewhere else, since there is no template for the motor mount, here is my "CAVEMEN" approach:DSCN7229.jpg DSCN7232.jpgDSCN7234.jpgDSCN7245.jpgDSCN7248.jpg
              I also drilled mounting hole patternes for TP 29xx motors, since these seem to be the last of the out-runners from FightCat. In case I don't have replacement motors, plan B is to use 29xx motors.
              Thanks for putting up with me guys, I know there are so many better builds and more interesting pictures. I am truly grateful for this Forum and all the people who are selflessly helping newbies like myself.
              • Ken_NJ
                RC Boat Addict
                • Sep 2013
                • 340
                Can I ask a general question about CF? I'm use to using polyester resin or Z-Poxy. Have not worked with West yet. What do you guys use with CF cloth?
                BTW, I'm following along and learning myself! Right there with you.
                  I didn't do the CF inlay myself, I had Rocstar did it for me. So I don't know what he used ( think he used West as well) , but I have done many FG inlays using West, it is great and I like it, because the viscosity is low enough that you can reposition many times( West 105 /206) . Z-poxy 30 min. epoxy is great but in general MUCH TOO Thick, IMO for any inlay work, the only alternative is their Z-Finishing -Epoxy. It is great stuff but I have done some tests: the cured left over in the mixing cup of the Z-Finishing Epoxy is more brittle than the left over West in the mixing cup. Now, I don't know much about what kind of quality is wanted in an inlay, but for mounting motor mounts or other tasks , I will mix some milled FG or filler to THICKEN the WEST epoxy, and the result is bullet proof.
                  • TheShaughnessy
                    • 1461
                    You can use the z poxy finishing resin, pt40 but it isn't nearly as hard as west systems, west is a much better structural resin.
                    Looking good so far Tim, twins sound so cool.
                    • Rocstar
                      Joel Mertz
                      • 1536
                      I used West System 105 with 207 clear hardener.
                      • keithbradley
                        • 3671
                        Cool build Tim. Are the batteries and ESCs both going in the tunnel, or are the ESCs going to be in the sponsons?
                        www.keithbradleyboats.com
                          Thanks, Keith!
                          The batteries will be on the tunnel floor , at least the majority of 5000mah/4s would not go in the sponsons without grinding away some of the hull---one of the reasons why I decided to make a twin out of it. My plan is to use two SK 120ESC and place them ahead of the motors in the sponsons.
                          I hope this is OK, especially for the correct COG.
                            Trying to see how the stuffing tube should be bent.DSCN7259.jpg DSCN7265.jpgDSCN7261.jpg
                            Although I will be using .150 cable, for alignment purpose, I use a 3/16" aluminum rod to line up the motor, I plan to use teflon liner as well, but I prefer to have a solid rod for this step.
                            Moving to the real thing:DSCN7266.jpg DSCN7270.jpg
                              Once I get the angle really correctly, I will tack the motor mount, then gingerly take down the motors and epoxy them GOOD, also I need to make stuffing tube supports.
                              Having only a power drill and a Dremel is proving to be a PITA for this build. I will buy fewer boats and invest in some tools.
