Mr Krabs build
  • Xzessperated
    • Apr 2008
    • 3063
    #256
    Originally posted by slimshady View Post
    by the way Viking what is the black char grilled mess in the bottom of your hull, is it the remains of a burnt out ESC or LiPo?
    I can get a new flexi but what next?
    Slim
    Slim that looks like the remains of some over cooked takeaway food
    After reading your comments I guess you have one choice. Drill two more holes in the flex shaft end of your coupler and then tighten all your grub screws up as tight as you can. I have been known to get a real bend in the Allen Key while doing the screws up. Use Loctite on all your grub screws on the drive shaft from the motor back to the prop nut. I have never had a prop nut come undone but I have taken note of what Viking said and will use a little Loctite there also from now on.
    You may have some handling issues with a flat CF turn fin. I have a flat one on one of my Xs 2's and it does not turn left well without sitting the boat on the water, prop side up.The other Xs2 has one with a curved bottom and it turns both ways well. Try to get used to going clockwise around your pond and it should be ok. BTW I have used and recommend Vikings wheel collar idea.
    Slim keep asking question as we are both learning. I have learned from Vikings comments (thanks Viking) and so we all benefit from each others questions and answers.
    • RandyatBBY
      • 3944
      #257
      One thing that is important to do is to have the motor free spin when you let off the throttle. Set up your SC to do this if you have any brake in the throttle it will do all kinds of damage. Flat spots for the grub screws are mandotory. I have not lost a flex shaft in a long time. allso I use silver solder on the end of the flex shaft to keep it from un winding and to give good bite for the grub screws on the shaft.
      Randy
      BBY Racing
      • Xzessperated
        • Apr 2008
        • 3063
        #258
        Thanks Randy. I have never used silver solder so I have a question. What do you use to melt the silver solder.
        • egneg
          • 4759
          #259
          I would think set screws (grub screws to some) at 90 degrees would cause even more vibration. I would put them at 180 degrees and make sure that the flex is a good tight fit as to keep it centered. Have you checked the coupling to make sure the holes are concentric (no run out) and it may not be a bad idea to check to see if it was balanced just like one would do with a prop.
          IMPBA 20481S D-12
          • RandyatBBY
            • 3944
            #260
            I use natural oxigen and acetylene in a tank. Borax flux and Harris 56% silver brazing alloy.
            Randy
            BBY Racing
            • Flying Scotsman
              Fast Electric Adict!
              • Jun 2007
              • 5195
              #261
              I heard Engineers earn more than that in an hour over your way[/COLOR]. Buy all three unless you have Scottish ancestors. In that case just have a Scotch Whisky and think about it. I really do not think that story about Scotchmen being frugal with their money is true. Douggies boats must have cost him a small fortune and he wears a dress, ooops I mean a kilt.
              Oh dear. First off, we are Scottish not Scotchmen, Ah but that is the sad tale of the Tasmanians. We love our whisky (scotch) but we are the result of many cultures. That is our problem and saviour ???
              Paddy and Andy, you are the best nuts I know
              Douggie
              Last edited by Diegoboy; 06-12-2009, 02:11 PM. Reason: fixed quote: (not cut & paste)
              • RandyatBBY
                • 3944
                #262
                This is great. We have a Scotsman and an Australian helping an Englishman. That is what forums are all about.
                Does it count that I am Irish, English, Dutch and Welch, with a little American Indian in there!
                Randy
                BBY Racing
                • Viking
                  • Jul 2008
                  • 137
                  #263
                  black mess
                  Hi Slim and you too Xz;
                  That black mess, that doesn't want to come out is the remains of the Eagle Tree magnetic rpm sensor, The wheel collar has the tiny magnet glued into a hole in the collar opposite the set screw. I got the RPM sensor a little too close to the collar and the set screw ate it ! I don't know what it was made out of but I can't get it off the hull.
                  Slim if you are worried about the set screw deforming the flex shaft tin the shaft with silver solder.
                  I can solder copper pipes all day and not have a leak, but I have a hard time with the flex shafts and silver solder. I solder my prop shafts onto the flex cable myself (Great Grand Dad came over from Scotland) and have had some failures . A small butane torch (under $25.00) available at home improvement stores here, will do a very nice job. Trying to put solder on a flex shaft is like asking the worm to get on the hook. I noticed that the end of the flex was nicely tinned after being soldered in to the prop shaft, SO, I drilled a hole in the end of a piece of 0.50 (1/2") Aluminum rod deep enough to tinn what I wanted of the shaft. I cut up some solder and put it in the hole ( rod held upright in my hobby vice) applied flux to the shaft and heated the rod with the torch, then I inserted the shaft into the hole with the melted solder. SLOWLY any moisture or oil might bubble out pushing the molten metal out before it. OUCH. Leave the shaft in there for a few seconds so it gets hot and takes the solder. When you take it out wipe it with a rag quickly and you have a lovely silver shaft.
                  DO NOT do this wearing shorts. When the lovely molten solder bubbles up out of the rod ,it then is affected by gavity and begins to fall, should this liquid metal fall onto your hairy leg it will stick to the hair and ouch. I have the scars to prove it.
                  Good Luck;
                  Viking
                  That Viking www.How2RC.com PULSO
                  Home made 36" DeepVee 50mph
                  • egneg
                    • 4759
                    #264
                    Good thing you are not a dog as they have a name for that sort of thing
                    IMPBA 20481S D-12
                    • RandyatBBY
                      • 3944
                      #265
                      Originally posted by viking View Post
                      hi slim and you too xz;
                      i can solder copper pipes all day and not have a leak, but i have a hard time with the flex shafts and silver solder. I solder my prop shafts onto the flex cable
                      viking
                      mistake
                      Randy
                      BBY Racing
                      • Viking
                        • Jul 2008
                        • 137
                        #266
                        Not to worry, my dog is smarter than that.
                        • RandyatBBY
                          • 3944
                          #267
                          Randy
                          BBY Racing
                          • Xzessperated
                            • Apr 2008
                            • 3063
                            #268
                            Douggie
                            And that is what makes you Scotch men Douggie. Sorry I did not separate the two words in my first post.
                            We love you too Douggie. You have to have a sense of humor in this world.
                            Now Randy does not know who he is. He has so many nationalities in him. We all know he is red, white and blue though
                            Chuck, my boss sleeps with his dog. Would that make him a Taxidermist?
                            • andym
                              More Go Than Show Prop Co
                              • 2454
                              #269
                              No Paddy that just makes him a Tasmanian!!!!!!!!!!! How did that sex tour of Launceston go? Get change out of a fiver mate. Douggie you realy have to come over..................................
                              • Flying Scotsman
                                • Jun 2007
                                • 5195
                                #270
                                Andrew, (please note the proper use of his name) I would love to visit the barren continent. I actually had a chance when I was 21 years old...job and all, but turned it down for the frozen north...you can see I am not the sharpest knife in the drawer!
                                The problem, as I perceive it, is Paddy. What is his background, as he seems to have this vengeance against all manner of birds, especially THE DUCK. I know he lives in this distant island called Tasmania but if I went there is a chance of me being captured for the knowledge of my famous burning newspaper up the arse trick?
                                Your obedient servant
                                Douggie
