New P Sport Hydro 2015!
  • Shooter
    Team Mojo
    • Jun 2009
    • 2751
    #571
    Wow Larry.....yeah, I'd say that's adequate! Looks like you've made a lot of progress. Nice!
    Mike - Good idea with the plastic bags.
    • TRUCKPULL
      • 3293
      #572
      Originally posted by Speed810 View Post
      LOL....That should do it Larry!!!
      I use some 1 gallon ziploc freezer bags, reinforce the bottom and side seams with duct tape
      And filled them with play sand. They work great and distribute the weight evenly. Plus their
      Cheap....lol
      I've used them on sheeting aircraft wings and now holding down boat parts square to the building
      surface. Also used them when decking the boat.
      Mike
      Mike
      I have a good use for Zip bags also.
      Look here; post #62
      http://forums.offshoreelectrics.com/...e-It-Seriously
      Larry
      • TRUCKPULL
        • 3293
        #573
        Pete
        I wanted to do the bottom with Epoxy instead of using the ZAP first.
        I felt it may be a little stronger and a better seal.
        I Hope
        Larry
        • T.S.Davis
          • 6266
          #574
          Pete, is it going to hurt your feelings if I make some changes to mine?
          Noisy person
          • TRUCKPULL
            • 3293
            #575
            Terry
            "P" class is 4S NOT 4 "D" size rocket motors.
            Larry
            • 785boats
              Wet Track Racing
              • 3423
              #576
              Originally posted by TRUCKPULL View Post
              Pete
              I Hope
              Larry
              Larry.
              I always epoxy the tub floor, the ride pads & the top decks.
              • Shooter
                Team Mojo
                • Jun 2009
                • 2751
                #577
                Pete
                I Hope
                Larry
                Good idea. I usually tack mine down first, then glass all the joints and let the epoxy flow underneath the gaps and create fillets. However, I think your method might be more robust. Do you go around and glass the joints after?
                yes
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2751
                  #578
                  A couple folks have mentioned making changes....and asked if it would bother me or not. I'm flattered you guys even asked!! It's your boat!! Do as you will!! I think it's great that people are making mods already!!!!!
                  • Shooter
                    Team Mojo
                    • Jun 2009
                    • 2751
                    #579
                    Just a quick update. I've changed the motor mount cross brace to read 'REMOVE AFTER DECKING' instead of 'REMOVE AFTER FRAMING'. I think there is still a slight chance for things to shift until the decking is installed. Last thing you want is the gap to close and the bolt pattern to be skewed. To be honest, I didn't even remove it on my last boat....I just left it intact.
                    • TRUCKPULL
                      • 3293
                      #580
                      Yes I plan to.
                      Larry
                      • TRUCKPULL
                        • 3293
                        #581
                        So it is OK that I changed something's?????
                        Sponson bottoms (0 degrees on right, 1 1/2 Degrees on left), G10 ride pads, ETC.
                        I was also thinking about some glass around the battery compartment floor (incase of a bad flip, the batteries do not break the seam)
                        Larry
                        • 785boats
                          Wet Track Racing
                          • 3423
                          #582
                          I just posted on my build log about this Larry, & then I saw your post here.
                          I laid some glass in the battery area and some 30mm glass tape along the sides of the tub & along the bulkheads & motor mount. Also over those holes in the bulkhead behind the battery compartment. Something I do in all the wooden hydros I've built, for the very reason you gave.
                          • JimClark
                            • 5913
                            #583
                            That looks like a very nice laser kit
                            Billy Graham
                              It would be interesting to try the 1400kv outrunner i have on 6S in this boat on 1P. I plan to run it in p-Sport though.
                              I was going to lay CF cloth if you guys think 5oz material is ok or too heavy?
                              • TRUCKPULL
                                • 3293
                                #585
                                Ray
                                The kit is pretty strong as is,
                                I think the 2oz and 3/4oz that has been suggested is good enough.
                                5oz may be too much.
                                Larry
