New P Sport Hydro 2015!
  • longballlumber
    • 3119
    #331
    OMG.... Your business model needs to be abolished! "Hi there gang, Pistol Pete here! RC boat designer, builder, and painter where we UNDER SELL AND OVER DELIVER!!!" HA HA, I crack myself up!
    Pete, you're NUTS!
    Later,
    Ball
    • Shooter
      Team Mojo
      • Jun 2009
      • 2520
      #332
      First things first. It's got to look good out there. Then, let's concentrate on prolonged floating and upside down power/steering control.
      • Shooter
        Team Mojo
        • Jun 2009
        • 2520
        #333
        Was out at the shop this afternoon. After fighting with the vacuum table for an hour, I switched to the smaller machine and just screwed the damn thing down. Turned out real nice.
        Any idea as to what to coat MDF with prior to vacuum forming? I suppose I could ask Phil P.
        • RayR
          @SiestaKey.calm
          • 1518
          #334
          I would be very interested in the answer to that question as well.
          • Shooter
            Team Mojo
            • Jun 2009
            • 2520
            #335
            Amazing what you can accomplish when you have an entire day off work! I sanded the bottom nose pc while the body of the cowl was machining (only 1.5 hours!). The cockpit was done prior. Sanded, sealed, and epoxy primed. I pulled a sample cockpit and nose pc. Decent, but they may require some small holes to improve the radii. Nobody said this stuff was easy!!!!!
            • Shooter
              Team Mojo
              • Jun 2009
              • 2520
              #336
              BTW - They don't look like much, but A TON of thought went into those two bucks. If this wasn't a hobby, I'd have gone broke months ago. The heights are extended slightly to allow square edges when you cut them out, and drafts were added all over the place. Plus, the front leading edge of the boat had to be designed in so it will mate well. Absolutely crazy time into these. Late nights.
              • flraptor07
                • Aug 2013
                • 2451
                #337
                Awsome Pete it's unbelievable the time you got in these, when are you gonna be ready to ship sets? Just let me know and I'll send you the $.
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2520
                  #338
                  Thanks Chris. I still have a lot of work to do on the hatch. The fuselage is going to drop into a recess in the hatch buck. Couldn't think of any other way of machining it without removing a ton of material.
                  Worked on this a little this morning. I'm not going to glue these pcs together because they will be used as guides to cut out future parts. I cut the plastic out of the window on another one, put it behind a black background, and scanned it in for the window decal.
                  • flraptor07
                    • Aug 2013
                    • 2451
                    #339
                    Man that looks like they fit really nice, the nose is nice and tucked too. You should get some slight aero effect (down force) from these and every little bit helps.
                    • JimClark
                      • 5902
                      #340
                      How are you going to lock the hatch down? Especially interested in the forward part of the hatch.
                      Sent from my SGH-M919 using Tapatalk
                      Billy Graham
                      • T.S.Davis
                        • 6228
                        #341
                        Pete, lets cut one from 1/32 ply for stringers and bulkheads. Then skin it with 1/32.
                        Noisy person
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2520
                          #342
                          Jim - If you look in post 335, there is huge overhang on the bottom of the nose that goes underneath. One pc of tape should secure it further if need be. That's how I do it on my current boat.
                          Terry - At first I was thinking 'glue sniffer', then I thought........that would actually be a pretty cool experiment!! Maybe 1/16 for stringers though??
                          I'm planning on cutting the main hatch out tomorrow night from 6-10pm after work. Nothing like being sharp and alert while operating expensive equipment that could cut your arms off!
                          • longballlumber
                            • 3119
                            #343
                            I am pretty sure right now everything is 1/8" right? I would stick with 1/16. I would also stick with 1/16 on the deck too. It would be too easy to put your finger though 1/32 in unsupported areas.
                            The thing is a tank right now, however that does have it's advantages. It will likely survive a longer life in a club racing environment the way it's constructed now. Just my 2 pennies...
                            Later,
                            Ball
                            • JimClark
                              • 5902
                              #344
                              My 1/10 the scale is all 1/32 ND ply it would be no problem
                              Billy Graham
                              • longballlumber
                                • 3119
                                #345
                                Jim,
                                This boat is being run on FULL P power. If they were running it on spec power it would be more feasible (in my own opinion).
                                Later
                                Mike
