Darin's MHZ Micro-Iceberg "SAW" boat Build
  • Darin Jordan
    • 9446
    Because I don't already have enough to do, I figured I'd take a few days this week and literally "throw" this little MHZ Micro Iceberg together to take to the SAW next week.
    A little "unconventional"... This boat would normally get a 28mm or similar power system and would rip with it.
    Brian Buaas held the N2 Offshore record with one of these a few years back at over 43mph on 6-Nimh cells.
    I figured it would be a fun attempt to stuff a NAMBA N1 Power system into it and try for the N1 Cat SAW record, which is currently setting at 37mph. NOTE: This power system I'm using came out of my N1 Mono, which holds the current N1 Mono SAW record at 40.6mph, with one of the passes being 45mph. This could be fun.
    Started with a clean hull that I traded some power system parts for here on OSE.
    Grabbed a quickie motor mount and located it. Motor has to be HORIZONTAL in order to get it under the hatch, necessitating an S-Bend stuffing tube.
    Stuffing tube is 5/32" aluminum with no liner. Flexshaft is 0.098 cable from OSE.com. Strut is an old Fuller's 1/8" lead-teflon strut on a 2" extended strut bracket.
    Rudder is a Micro rudder I found here on OSE.com. Worked out perfectly.
    Not really much to "build" on this. Once the motor mount was located, using two stainless 4-40 screws, I used JB Weld underneath it to take up the voids left by the "V" shaped center section and basically permanently glued it in place.
    Fabbed up a quick carbon servo bracket to hold the Spektrum A3010 Micro-Servo and epoxied it in place down the center.
    Hooked up the steering and installed the Castle Mamba Max Pro ESC in the right sponson, along with a cooling fan and the Spektrum MR200 RX.
    Motor is a Thunder Power Z3R-540 17.5T ROAR Stock motor.
    Battery will be a DinogyLipos.com 2250mAh 65C pack that Mark F. is delivering to me next week down at Legg Lake.
    Total weight with the new battery should be around 1lb 8oz. It's 1lb 9.7oz with the 2700mAh Thunder Power 70C that is in there now (see scale picture). Battery will fit, but I don't think I need that large of a pack. The Dinogy should be just about the right size.
    That's pretty much it. Went together in just a few nights. Quickie, but I think it actually turned out pretty nice.
    Darin E. Jordan - Renton, WA
  • Darin Jordan
    • 9446
    Of course... I had to show the love...
    Also got some new OSE.com stickers from Steven with the rudder order. LOVE the coloring, Steven! Thank You!!
    OH, and trimmed up some of my old Spektrum decalls (DX6, DX8, etc) to show a little love to the Monroe Bearcats, Class of 1986! :)
      • 7512
      Cute...
      This has to be your shortest build thread ever.
      • Darin Jordan
        • 9446
        Cute...
        Hahahaa... Short boat... short build... Not a whole lot to highlight, really. :)
        • Chrisg81983
          • Jul 2011
          • 1585
          Brushless MHZ Iceberg micro "directors cut": http://youtu.be/psp1d6IqKyw
          Hey Darin how have u been ? Friends and I have been into these hulls for quite some time. The hull can easily run at your target speed and much higher with ease.
          Anyways she looks great I am eager to see her run.
          • Darin Jordan
            • 9446
            Wow! That's inspiration for sure!
            Hopefully I've put this together in a decent fashion so mine will behave as well as yours does.
            I'm likely not working with as much power as you have there, but I guess we'll see how it goes.
            Thanks for sharing that.
            • Chrisg81983
              • Jul 2011
              • 1585
              Unfortunately that video is not mine lol I was just posting to show u what they are capable of. That guy is running a neu 1110 - 1.5d on 3s for 60mph and 4s for 65mph with a turnigy 90 amp controller. There are tons more out there that run equally as well and better.
              You should be able to hit your target speed/s with no problems at all.....
              • kacordy
                • Oct 2012
                • 484
                I hope you get the record. Allen
                • Darin Jordan
                  • 9446
                  Allen, are you coming down?
                  • kacordy
                    • Oct 2012
                    • 484
                    I will have to wait for spring. I'm going in Monday for knee surgery. I will have to take it easy for a few weeks and follow the Doctors orders. It's actually a good thing. I'm ready to eliminate the pain and get back to normal. If you can take a 30 minute break as you pass through Redding, I would enjoy the opportunity to have a meal with you?
                    Allen
                    • treystoys
                      • 180
                      Hey Darin very cool build. With an s bend I would be a bit cautious about that cable directly on aluminum for the stuffing tube. If you have done it before then ignore me lol but I'd hate to see the cable eat the stuffing box. And its just that I've seen .098 cable do some silly stuff under load and high rpms. Kinda ties itself into knots! Good luck man!
                      Trey
