quick vac u pickle build
    Originally posted by Doug Smock View Post
    Here you go fellas. My guess is that Travis will use something other than Hockey tape. It's not impossible to blow the boat off with the dam, but it does help a bunch.
    Try it approx.3" back in the tunnel.
    [ATTACH=CONFIG]121826[/ATTACH][ATTACH=CONFIG]121828[/ATTACH][ATTACH=CONFIG]121829[/ATTACH]
    Yea....I'll definitely blow it over. I may step down on my motor choice hehehe
    O...and yea....I'm devising a method right now to seal the hatch with no tape....doug....you know me all too well!
      Travis, this is mine, built by none other than Doug Smock. I have an UL-1 motor with x642prop. At this speed there is no blow over yet, very stable, love the boat!
      Don't mean to clutter your build thread though.
      Can't wait to see what you come up with.
      Here is a clip:
        Here is a clip:
        https://www.youtube.com/watch?v=e3GVsLhwBGA
        No man you not cluttering! I appreciate the video...this is one i saw a while back and was drooling over. I love that boat! Best looking one I've seen. She runs nicely! I'm out in the shop right now. I just stripped it and I'm painting the interior black. I can see it now it's gonna look nasty real quick if I leave it white. Be back shortly...
          Got the interior painted. Turned out nice. Got the tray fitted.
            I love the CF battery tray on the black interior. What kind of paint did you use? I remember the instruction cautioned the use of specific paint and glue.
              It said to use enamel. I'm pretty sure that's what it is. If not I'll be buying a new hull and starting over hahaha!
              • Chrisg81983
                • Jul 2011
                • 1585
                Travis this hull is a blast...it took me a little to find proper cg. Once I dialed her in with the help of Doug s advice it was an entirely new boat. Mike and I actually take his mhz nomad which is actually 3 times the size and race oval together. This little boat has a ton of hard use it is still like new. For example I tried running my ul1 that I had the same way and it didn't last too long. The prop that I found to work best is a X 442. It was a fun boat to build, and iwould not mind doing another one.
                • Doug Smock
                  • 5359
                  Mr. Smock, I thought the air dam is supposed to block the entire width of the tunnel, I am sure there is a good reason for a 'partial' air dam like the one posted in your picture, would love to learn more.
                  I have tried it both ways. The one pictured has been on the boat for at least two years. Play around with it and see what you think. It's really only an issue when the wind is up during a race. I have also added approx. 3 oz. of lead right at the front end of the motor if conditions are poor.
                  In ideal race conditions this boat can walk away from the bigger limited boats.
                  Sorry to trash up your thread Travis. Hope some of this helps. Nice work BTW.
                  PS Mr. Smock was my dad.
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                    Thanks! Coming from you that means alot! :)
                    You guys aren't trashing my thread. This is very useful information I can use. If I like this little boat, I may get one for myself.
                      Thank you , sir!
                        • Luck as a Constant
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          I think this is your first non cat build.... At least what I've seen.
                          Hydros are fun...
                            Hydros are fun...
                            This is my first non cat build. Not bad for a plastic boat tho. I have another hydro on the way to me to go through for Scottm. Then there's one i want in the ose store that comes in green I want but it's out of stock. When they get more in I'll get one. I'd really like a carbon Popeye tho....
                              Hydros are fun...
                              A build like this would just be a quick snack for Travis!
                              The green motor looks really good with the silver jacket against the black interior. is this the 1415?
                                Yes sir, it's a 2400kv 1415 being run by a mm2 that I've got to make a cooling block for. Start on 3s......and work my way up (when I'm driving it that is!)
