Exceed flowmaster cat
  • TheShaddix
    • Sep 2013
    • 759
    Hi Everyone,
    Just wanted to share one of my builds. This is my first time posting a build on the forums, and I wanted to use this opportunity to say my thanks to the community and everyone I've ever PM'ed for help and questions. And, most importantly, I wanted to thank Manuel for his help throughout my rc boating experience. His patience knows no bounds, such a humble and modest guy with tons of knowledge. I appreciate his time and effort to answer all my questions and some day I hope to return the favor somehow.
    Here is my build, plain and simple... This cat started its life as a fiberglass hull, 650mm in length. I stripped it down, did a hull and hatch inlay with 12k cf, plus 4lbs density foam in the bow, and other cosmetic junk. I had a lehner 1940 laying around, so why not throw it into use on this one... Although it's "slightly" overdone in the power aspect, this has been one of the most fun projects to date. If it doesn't sink right away, it'll be using 2 dinogy 3s batteries (65c - 4000mah) in series (6s...) with a seaking 180A V3 ESC. Should make for a fun launch.
    Here is what it looked like before:
    And here is what I have so far
  • TheShaddix
    • Sep 2013
    • 759
    Here are my other 2 hulls that I'm building, an mhz 114 and 138... And my third cat on the bottom there.
      Nice work. I lie the look of that Exceed.
      • Shun Tung
        • Oct 2012
        • 124
        Dear Theshadix master,
        May I know when you buy this hull from hobbypartz that boat is it already installed all hardware ? ( like the picture)
        For etc : motor mount , flex cable , rudder . You need removed all the already installed all hardware part inside the boat then cover the CF sheet . Please advise ! Thanks !,
        • TheShaddix
          • Sep 2013
          • 759
          I took everything out of the boat, yes.
          • Shooter
            Team Mojo
            • Jun 2009
            • 2751
            That hull has amazing detail. Anyone know if it's still available?? Nice job on the build so far.
            • Shun Tung
              • Oct 2012
              • 124
              Thanks you so much TheShaddix reply !
              • TheShaddix
                • Sep 2013
                • 759
                Says it's out of stock everywhere... I finished this build, but my goal of running it at over 50 mph on 6s didn't pan out so well - it had too much torque roll and would jump out of the water and do multiple corks around itself every time, even from a rolling start. It's really nothing more than a cute little toy boat with an outstanding paint job and detail. Knowing that I wouldn't be happy with it running any slower, I sold it to someone local who now enjoys running it conservatively.
                • Shun Tung
                  • Oct 2012
                  • 124
                  But I saw exceed rc web suite still in stock but just only kit not ARTR . I saw the photo same to you also only
                  Hardware no motor and ESC coming. Do you think this boat if I running leopard 3650 2090kv 4S lipo or any
                  Recommend best of this class motor for sport running ? Please advise ! Thanks !
                  • TheShaddix
                    • Sep 2013
                    • 759
                    As long as you stay within 35-40 mph, the boat is fine. On 4s that motor is good for sure.
                    • Shun Tung
                      • Oct 2012
                      • 124
                      Thanks for your advise !
                      • Shun Tung
                        • Oct 2012
                        • 124
                        Dear TheShaddix,
                        Would you please tell me if I use original hall is it good enough room to install like you seaking V3 ESC and I hope use leopard 3660 2120kv ? Please give me some advise or I need to modifty like you this hull can be install this ESC and Motor ? Please advise. Thanks you so much !!!
                        • TheShaddix
                          • Sep 2013
                          • 759
                          Which seaking v3? A seaking 180 will not fit unless you shave off the bottom. Grab an 80a or 90a seaking. It'll be good if you only run 4s with a 38mm or 40mm prop. The motor is good and will fit without an issue.
                          • Shun Tung
                            • Oct 2012
                            • 124
                            It is 120A seaking V3 . I think same as your photo . I sorry forgot telling you !
                            Do you think is it OK ? Is it 120A and 90A almost same size ? What is your
                            Seaking ?A in Photo ? Please advise ! Thanks you so much for your reply !
                            • TheShaddix
                              • Sep 2013
                              • 759
                              120a will fit fine. Anything bigger will not fit comfortably. But don't run any more than 4s on that motor with 120a.
