crc outerlimits
  • tazman
    • Apr 2014
    • 124
    crc outerlimits
    Just starting my build of my crc 70in outerlimits. Will be powered by cc2028s on 10s 150c 8000 mah maxamps lipos. Drives will be ashark m8s and all internal parts will be cf. Have build boats before but this is my first using cf. What is best to use for bonding to the hull? Thanks for any help. Pics soon.
  • iridebikes247
    • 1669
    Cool looking boat and drives. I suggest West Systems 105/207 epoxy this is the epoxy most of us use. There are a lot of additives out there I would pick up some black pigment, 404, and 406 fillers. For additional stuff like battery trays, servo mounts, etc, I would look into Dragon Plate cf plates, probably some of the hardest plate you can buy you'll see what I mean if you ever have to drill it. They sell a lot of stock discounted and its reasonably priced.
    • tazman
      • Apr 2014
      • 124
      Thanks for the info. I have been on dp site and they do have very nice plate. I plan on mocking up everything with ply and sending the pieces to be cnc out of cf.
      • Espresso
        • Jul 2011
        • 248
        Very nice drives! Been eyeing those for a while but they're soo expensive and you got TWO of them. Wow, looking forward to your build and review of the drives.
        • Vin-m
          • May 2014
          • 308
          those drives are sick! who makes those?
          • Rocstar
            Joel Mertz
            • 1536
            • tazman
              • Apr 2014
              • 124
              Arrow shark makes the drives. They are very pricey. They do run specials from time to time. I got mine at 20 percent off with two sets of props free. They say they will handle 10hp. We will see. They do have spare parts and will be ordering a couple sets of gears to have.
              • flraptor07
                • Aug 2013
                • 2451
                They look awsome and if you're building a scale type boat the look realistic, but don't they eat up some HP to drive them?
                • tazman
                  • Apr 2014
                  • 124
                  They will eat up a little. They spin pretty easily because they have 10 bearings in each drive instead of bushings. Building for looks and fun running. Hoping for 60mph all day long witb no problems.
                  • Espresso
                    • Jul 2011
                    • 248
                    60mph on that size hull should look sweet on the water. Hope your build will come with a nice fitting paint scheme to match the use of scale drives.
                    • tazman
                      • Apr 2014
                      • 124
                      After any bugs get worked out plan on sending it to steve at the airbrush alley for paint. Thanks everyone for the compliments. Work has been busy but hope to get going this weekend.
                      • olwarbirds
                        Magic Smoke Wizard
                        • Oct 2012
                        • 1194
                        Brent, this is going to be a beautiful boat. I was also looking at those M8's. It appeared to me that they were designed for gas applications. Did I miss something ? Did you get some kind of an adapter ? DJ
                        • tazman
                          • Apr 2014
                          • 124
                          They are designed for gas mainly because of the 1/4in prop shafts. It limits wbat props you can use for electric. I will be using custom cut 50mm from the propshop with 1/4 in hubs. Tbey also told me they should handle the rpm. Uncharted territory I know. Lol
                          • tazman
                            • Apr 2014
                            • 124
                            Just wanted to say that that square end of flex shaft simply inserts into the drive which I will keep as short as possible to keep friction and vibration down. Tips of couplers will be about an inch away from the transom.
                            • iridebikes247
                              • 1669
                              mbp sells steel props with 1/4" with 55mm and 61mm available.
                              A lot of guys over in germany use these on the bigger 70" boats they will be slower than 1.4 pitch but might work really nicely on this, figured I'd throw it out there.
