Aeromarine Team Believer with updated hatch build. Special
  • rearwheelin
    • 2101
    #451
    Ok I'm kind of pissed that I just ruined my motor . The isolating material the factory uses sticks out the motor ends where I cut them and I don't know how to get that stuff off lol
    --Albert Einstein
      Randy, you have to use a hobby knife to scrape one individual wire at a time, it is a famous PITA, but it will get you there.
      Sorry, but patience.
      • rearwheelin
        • 2101
        #453
        Thank you very much for the tip ! I almost threw it across the yard ! lol
        --Albert Einstein
        • rearwheelin
          • 2101
          #454
          --Albert Einstein
            I hear you, there was a discussion and some use chemicals, but I just craped mine, although it was a smaller motor with many less individual wires.
            Sent from my D6708 using Tapatalk
              When you get the MGM load the disc in your computer and just study it to get familuar with it. That is the only draw back to MGM if you want to call it that, is the only way to program is through your PC. You also not only have to calibrate your radio to the ESC you also have to calibrate the ESC to your radio and you have to do it EXACTLY how it says to. Here's the video on setting the throttle limits, the boat esc is the same except no reverse.. https://www.youtube.com/watch?v=GLzM5xyzseM
              What? I have reverse on mine! Lol
                Ummmm when I saw that pic where you cut the wires on the motor....I said ugh o....I hope he knows what he just did. Maybe using the wire brush on a bench grinder carefully will help. I have not yet come across this issue yet but I hardly think it could whip me.
                • rearwheelin
                  • 2101
                  #458
                  I was thinking about taking a wire dremel wheel to them .
                  --Albert Einstein
                  • rearwheelin
                    • 2101
                    #459
                    Besides the fact that it's doable making this thing right do I really want to spend the effort on a $150 motor lol
                    --Albert Einstein
                      Much better idea than my hobby knife.
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #461
                        Really Travis, I never even tried I just figured the boat esc didn't have reverse. I must have mine disabled some how cause it doesn't have it now! LOL not that I really need it on a Hydro, it would probably just go under if you tried backing up. The transom is level with the water just sitting there...
                        • rearwheelin
                          • 2101
                          #462
                          --Albert Einstein
                          • rearwheelin
                            • 2101
                            #463
                            It's done but I won't do it again. You need two new wire wheels for this and I'm confident it's almost as good as before there pretty short now lol
                            --Albert Einstein
                            • rearwheelin
                              • 2101
                              #464
                              You didn't study the disk good !
                              --Albert Einstein
                                [ATTACH=CONFIG]130826[/ATTACH]
                                YAY!! You did it. Awesome!
                                Randy, I had the same reaction as Travis when I first saw the pictures.....
