MHZ 138 Johnnie Walker Tribute
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    Hi All,
    Its been a while since I have posted a build, but many things have been going on and moving house has been one of them. Getting back into it all and setting up a new hobby room has been a P.I.T.A. not to mention getting equipment up and running.
    Ok! A fella hits me up asking if I would be interested in building a boat in memory of he's late father... I thought it was great idea, knowing what it feels like to loose a parent.
    The extreme was, that he's dad loved he's whiskey, and shared the same name as he's favourite (Johnnie Walker) Couldn't be more of a challenge for a fella like myself.
    So to kick it off, here are some of the features of this very cool project in memory of Mr. Johnnie Walker "Keep Walking".
    Hull: My personal, MHZ138 special carbon/kevlar/carbon lay-up
    MHZ Rudder
    Click Drives from MBP
    SF240's
    TP's 5660/1000kv
    Savox servo
    Carbon Parts by Yours truly.
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    Alright, As mentioned this was a special order hull I had made for myself by MHZ. It is the standard carbon/kevlar, but with a final carbon inlay from factory. Definitely one of the hulls you wanna hang onto if you can get one. Anyway, I started as I usually do by making up my templates for the drives to ensure the mounting is 100% correct on both sides. I should mention this hull is very well made and not the slightest out of alignment. I use a CNC cut 1/2' acrylic template that allows me to line up the the holes and drill 100% perfect holes on both sides...
    After the holes are drilled, everything just lines up! its made in a way that I can simply turn the template around and repeat the step on both sides.
    Click drive fit close up.jpgClick drive template.jpgClick drives hole drilled.jpgClick drives templates all drilled.jpgClick drives templates close up.jpg
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1876
      I have to say, I hate the top part of the drives and always worry about getting that part wrong, so for the first time I made a template for those as well. I just didn't want to take any chances stuffing up this hull. This template was also CNC cut, but made in carbon fiber. Photos in no particular order!
      Click drive top drilled.jpgClick drive top how it looks.jpgClick drive top measure.jpgClick drive top prepared.jpgClick drive top stuck on.jpg
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        The result, 100% perfect alignment!!
        Click drive alignment perfect.jpgClick drive just on.jpgClick drive top test.jpgClick drives just in.jpgClick drives just mounted.jpg
        • nata2run
          customcfparts.com
          • Nov 2011
          • 1876
          Next were the motor mounts, featuring the JW logo with chrome foil. As usual, there is a bit of sanding and alignment to do for those to fit right. This time I completely redrew the mounts so I could fit the infill with out having to compromise. The mounts also got measured to fit this hull in particular, and the spot I wanted them in.
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            I found, aligning the mounts without considering stuffing tubes lets you see the bend of the cable before its encapsulated. The tube can then be bent to fit. No binding what so ever in this system.
            • iridebikes247
              • 1669
              Awesome job Kent, the 1000kv motor is very powerful. Drives look great too, I always get nervous before installing the flanges and especially pedestal mount lol
              • Xcesive8
                • Jul 2009
                • 439
                Geeezz how was outa space buddy, you've been gone a while!
                Good to see you getting back into a build..
                Without a doubt its going to be very nice!
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  Thanks Ryan, outa space was truly outa space lol hope you been well
                  • PowerDemon
                    • 353
                    Fantastic looking build! Can't wait to see it finished.
                    37" Fightercat Shocker powered by Neu 1530 on 10S
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1876
                      Thanks buddy, yes you are right about the motors, they seem very powerful. Cant wait to do a maiden
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        As usual, I did the stuffing tubes with carbon wrap, not that its needed but it gives a nice look to the whole system and also helps bond better to the spacers/supports. I used some masking tape around the tube supports for better look before I epoxied them in. I should mention tubes and cabels are from Gundart Germany. Collets are Lehner 8mm to 1/4"
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1876
                          Off she went to the spray painters for a bit of color. Very hard to see in pictures, but its a Saphire black, BMW metallic. They did an amazing job, and being a marine restorer they know how to handle a boat!
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1876
                            Next was the water intakes...I drilled out the holes with a smaller drill and ended up sanding until the tubes fit. Its always a good idea to use masking tape before you drill any holes. I also taped around the tubes after install so I could sand then nice and flush. Once done I further taped in a square shape around the intakes to get the size of the tear drop cut. This way I know they are identical on both sides, and that I'm cutting in a straight line. (I have a few more images, will upload when I find them)
                            both intake tubes fitted.jpgboth intakes cut up close.jpgclose up for sanding.jpgCuttin intake with dremel.jpgIMG_5803.jpg
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1876
                              On to the rudder and hydraulics part. Nothing unusual there, except MHZ need to do the hydraulics a bit more in the style of HPR. The long grove and way off center screws don't do it for me on this 138 model. But never mind, It can still be fitted. I do like to run the wires in teflon tubes, but the parts don't seem to be setup that way. Using masking tape is a good idea, you can measure and write on it. Then a ultra thin double sided tape will hold the parts in place as you drill holes.
