fantasm 41 build
  • flraptor07
    • Aug 2013
    • 2451
    #46
    Originally posted by Apophis View Post
    I had a little water getting in my Daytona after running her most of the summer. Took me a while to figure out where it was coming from. At first I thought it was in my cooling system and tested it with pressure and that wasn't it. Doing water tests with the hatch off made it hard to find because it was almost like it was oozing up thru the inlay lol. So I put my hatch bolts in, taped her up and left one of my shafts out. I had a little cup with some soapy water and my syringe, I blew into the open shaft (god that sounds bad lol!) but it pressurizes the hull, then used the soapy water around all my hardware to find the leak, kind of like looking for a rim leak on a tire. I see you are using two piece shafts so maybe you could take one of your water outlets off to pressurize it(plug the other end), Hope that helps.
    This is a excellent way to find a leak, I gotta remember this one!
    • rearwheelin
      • 2101
      #47
      I just ran my Titan after sealing putting sealant on the hardware. Not a drop now . During my previous testing runs it consistently had less than a ounce of water. Not a drop in 2 runs !
      --Albert Einstein
      • Vin-m
        • May 2014
        • 308
        #48
        Just ran in the pond by my house and the lvc setting fixed the esc problem. i did 54.1 mph on the gps with 447 props. temps were 105 motors , 110 batteries, 115 esc's and the caps on esc's were 145 . is that hot for the caps and what should they be? still got alot of water in my boat just like before about 1/4 cup or so. when you guys do hardware do you cover the entire piece of hardware with silicon and then just wipe excess clean after installation? or do you fill the holes and screws only and then install hardware?
        • rearwheelin
          • 2101
          #49
          I'm pretty sure your batts aren't throwing enough amps, that makes the caps work too hard.
          --Albert Einstein
          • Luck as a Constant
            Make Total Destroy
            • Mar 2014
            • 1952
            #50
            I just use plumbers putty. Much cleaner and comes off in the future.
            Honestly, there's never really been the need tho.
            • Vin-m
              • May 2014
              • 308
              #51
              do you put the putty on the outside of the hull or inside, on the hardware or screws?
                Make Total Destroy
                • Mar 2014
                • 1952
                #52
                I would just put a little where the screws went in.
                  I put a light coat of Honda bond on all mounting surfaces and on the screws. Then after I tighten I wipe the excess off
                  • flraptor07
                    • Aug 2013
                    • 2451
                    #54
                    Honda bond is some killer stuff, that's what I use on 4 wheeler and motorcycle cases don't need any gaskets.
                      • 9481
                      #55
                      your temps sound good
                      • rearwheelin
                        • 2101
                        #56
                        I am a honda bond 4 user ! Get it right lol great stuff . It is a little over kill for our applications but it will work the best, just used some on my T29. I like LAaC plumber putty idea, much easier to clean up the surface should you have to pull hardware .
                        --Albert Einstein
                        • devo
                          • Aug 2012
                          • 156
                          #57
                          I have the same boat and also have the scale rudder with the push pull set up. I find that water is coming in the boat between the turn cables and the sleeves. I now put some heat shrink around the area where the cable protrudes out of the sleeve, plus I now fill the sleeves with corrosion x before each run and now it doesn't leak much at all
                          • rearwheelin
                            • 2101
                            #58
                            145 degree caps are good ?
                            --Albert Einstein
                            • PowerDemon
                              • 353
                              #59
                              Yeah the hottest my caps ever was 220F... I let it cool for a bit afterwards
                              37" Fightercat Shocker powered by Neu 1530 on 10S
                              • rearwheelin
                                • 2101
                                #60
                                Naw , they are smoked then.
                                --Albert Einstein
