New twin rigger
  • twissted
    • 867
    #76
    It's a good looking boat. I'm looking forward to a running video!
    twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!
    • urbs00007
      • Jun 2011
      • 826
      #77
      twin
      Originally posted by grsboats View Post
      The problem is now solved with fiberglass roving around the rudder servo bulkhead...took me time to do this repair but now its much more strong.Yes in front there are the receiver and the battery.After a close inspection I can say the hull is in perfect shape and ready for more action.Unfortunetely the lake is not long enough so I will test props with less pitch and less lift just to see its maneuverability.thanks Gill
      gil, why don't you use castle bec to save some weight?
      • grsboats
        • 972
        #78
        John I don't think that a 50grams receiver pack is an issue.Boat ran really nice but the main problem ,just figured out arriving at home,was the rudder blade failure.I still can't believe that a Speedmaster rudder can suffer this damage but with all the power and pressure in the transom during a turn at high speed it happened.Wednesday will be the next water test and hope evrything come true to post a nice video.Thanks Gill
        GO FAST AND TURN RIGHT !
        www.grsboats.com.br
        • flraptor07
          • Aug 2013
          • 2451
          #79
          Gill, is it the picture or am I seeing the leading edge rolled on that prop that is next to the rudder?
          • grsboats
            • 972
            #80
            Ok boat repaired and going to water tomorrow.Gill
            www.grsboats.com.br
            • urbs00007
              • Jun 2011
              • 826
              #81
              twin
              good luck with repair. did the boat hop which in turn, bent the rudder? maybe andy brown could set you up with his twin 90 rudder? looking forward to video.
                • 9479
                #82
                Looking forward to it man!
                I really want to build me a twin after seeing this build
                • grsboats
                  • 972
                  #83
                  Hi fellas as promised boat went to water today.Not the best day for boat testing as it was very windy and choppy and we had to wait two hours till things could slow down but I couldn't resist and went to water with conservative power to be on the safe side:Aspec 5S 4.4A and Prather 240 modifed. Rudder blade substitued by a CMDI one reinforced with c.f.....everything went good for now.video: http://youtu.be/MBL7RGrzmdY Thanks Gill
                  www.grsboats.com.br
                  • urbs00007
                    • Jun 2011
                    • 826
                    #84
                    twin
                    liked your launch ! easy on the throttle ! lots of power, yes? good job, gil.
                    • grsboats
                      • 972
                      #85
                      Thanks John.Riggers are different animals compared to other classes so takes time to get them properly dialed.I'm not sure what is the problem but what i'm observing is the left motor is consuming more power than the right: after a meter inspection I had 32% on the right battery and 21% on the left.Both are well balanced with low IR.I will need to make more tests to confirm if there is any difference between motor's power.Thanks Gill
                      www.grsboats.com.br
                      • urbs00007
                        • Jun 2011
                        • 826
                        #86
                        rigger
                        just a thought, maybe swap props. maybe they arent drawing same power. 2 castles with data-logging would be nice, huh?
                        • flraptor07
                          • Aug 2013
                          • 2451
                          #87
                          Gill, sounds to me like they messed up packaging those motors and sent you two different motors, you should check the kv on them.
                          • grsboats
                            • 972
                            #88
                            Motors are Ok.Just reset my esc's and reprogrammed them correctly...timing was wrong with one .Next weekend if weather is good more action and tests in a big lake.Thanks Gill
                            www.grsboats.com.br
                            • grsboats
                              • 972
                              #89
                              Some updates: spent the whole weekend testing the boat with different props and figured out that an unkonwn problem with the left motor is causing a big interference with the top speed...definetively motors are spinning different rpms.Removed the TPpower and replaced with 2 Neu 1527 1D on 6S and SF 240 with datalogging......now what I can say is driving this boat is a joy.Temps,amps and and speed are great.This week more tests with video.Thanks Gill
                              www.grsboats.com.br
                              • urbs00007
                                • Jun 2011
                                • 826
                                #90
                                twin
                                hi gil, how does the swordfish compare to the castle 240? glad you solved the motor tp motor issue. was the issue with the esc or motor?
