help newbies with setups
  • darryl whitman
    • 535
    I'm hoping this thread may help new comers with their boat setup,
    I see members asking what motor. esc . batteries . an props to runin their boats, so here's what I'm asking for , please list,
    1 type of boat.
    2 type of racing, heat laps , saw, oval.
    3 motor ,esc ,batteries = cell count , mahs of pack.
    4 what prop,
    1 ML gp310 hydro,
    2 oval racing
    3 AC 2030KV motor , AC 60 amp esc, 2x 2s 5000mah batts,
    4 prop 442 , working on cupping
    1 JAE 21 rigger,
    2 oval racing,
    3 Dr MadThrust 3674-1600KV motor, seaking 120amp esc, 5s 5000 mah batts.
    4 prop ABC 1914 B/S, nice but you should run a bigger esc, like a 200amp.
    • 7990
    JAE21FE
    Oval racing in P Hydro
    Castle 1415/1Y, Castle ICE200, 4S1P/5000mAh
    Cupped ABC H-7
    Insane FE-30
    Oval racing in P-LSH
    Aquacraft 2030, Castle ICE100, 4S1P/5000 mAh
    Cupped ABC42x66
    • darryl whitman
      • 535
      come on guys . plz list your set ups
      • 785boats
        Wet Track Racing
        • 3169
        Here's a couple of mine Darryl.
        ML Boatworks GP400.
        Oval racing ,EB Sports Hydro.
        TP Power 4070 1440kv motor
        Seaking 180A ESC.
        6s1P (2 x 3s) Entropy 5800mah / RC Boat Bitz 6000mah packs
        Prather s240 de-tongued & back cut.
        Ariane II
        TP Power 4060 1600kv.
        Oval racing, EB Mono
        Seaking 180A ESC.
        Entropy 5800mah/Revolectrix 5500mah 6s1p.
        X646/3 blade, partially de-tongued.
        ML Boatworks GP310
        Oval racing, EA Restricted Sports Hydro.
        Pro Boat 1500kv motor.
        Aquacraft 45A ESC.
        China Hobbyline 5000mah 4s1p (2 x 2s)
        M645 prop.
          • 9438
          Whip 40-36" long.
          Oval racing, Q-Sport Hydro
          TP Power Custom 1250Kv "Y" wind.
          SF240 esc set to "middle" timing (had no PC), SF200 worked o.k. for 2 heats and then melted a connector off, it was used with factory defaults, maybe why it got so hot??
          Revolectrix 60-120C 6S2P 4400's. - 8800Mah total
          Went from D/Tongued 452 down to M447
          DF33- P-Mono Oval racing
          Neu 1521 1.5D 1900kv
          Older SF200 6S esc
          4S2P Turnigy 25-35C 5800mah each, 11600 total Mah (cells are 3 years old now)
          D/T 452 for 6 laps, very D/T x450 for 4 minutes Offshore course
          Promise Hobby 40" mono Carbon Kevlar Layup (was shotty layup needed working on the bottom)
          Q-Mono, Q-Offshore Oval Racing
          HOR SSS 5684-1200kv motor D wind
          6S2P Dinogy 5000's 10,000 total
          SF240 esc set to Zero degrees timing
          Prather 240 for 6 lap race, D/T 638 for offshore 4 minutes
          • martinsson
            • Jul 2014
            • 11
            DIY aluminium outrigger 65x10x8cm (LxWxH) main hull, 30x6x6cm ouriggers 18cm from main hull total length 75cm
            Just for fun racing with fellow RC boat DIY'ers.
            Feisuda 380 2848-2636KV motor
            3S RFI 1300, 2200 and 5000 mAh
            4S Vapex 3300 mAh (have not tried it yet)
            DHP 70A esc
            Fixed axis w. 3-blade prop.
            All hardware found used is from a stock dragon hobby sword donarboat since I hace dificulties getting propper RC hardware locally, but now that i found this place (offsore electrics) I hope to get things in order.
            It runns fine once it gets going, but it struggles to get up out of the water, I plan to post build and "race" pictures in the forums in the future.
            • darryl whitman
              • 535
              JAE 21 rigger - amp tramp
              oval racing I hope to
              neu 1515- 2200kv SF esc 220 pro + , with 5000mah 4s lipos
              abc 1818 B/S from Mark S,
              she's running real warm on the output shaft of motor, may need to set timing up an or do some prop work?
              • grsboats
                • 972
                Darryl my FE BOATS ARE FOR SAW so:
                GRX rigger TPPower 4060 2040kv T-180 on 6S
                GRX C.F rigger NEU 1527 1D Castle Ice 240 on 6S
                GRX Twin TPpower 4050 2220kv T-180 on 6S
                ........speeds from 95mph to XXX.
                GO FAST AND TURN RIGHT !
                www.grsboats.com.br
