Basically the super cooler is done . I will fill it and Velcro it in later in the build.
I decided against this in the Titan instead it's going into the Team Believer . It's getting the new TP 56mm x 68mm 1800kv can so it needs it more .
--Albert Einstein
Laid up the boat finally ! Wanted to try a new type of motor mount . Seems that it will do a good job and I'm really liking how easy it is too make !
--Albert Einstein
The new 4.25" Speedmaster rudder is perfect ! I have a feeling Rossi will sell a bunch of these !
--Albert Einstein
Not sure where the esc will go now , it might need a new home
--Albert Einstein
So the motor mount looks special but just tried to flex the motor around on it and it's really strong ! Must be that putty and JB weld lol
--Albert Einstein
I'm not sure what's too much weight for a T29 . My scale isn't accurate but I think the weight is going to be high for this boat once I add oil to the esc , drive system and batts. . I'm really liking the trick look of the esc though. I think the boats at 5-6 lbs allready as seen. I will probably need to run the batts in the side and that is going to be a tight fit with 4s packs unless I use a different esc then I can run batts in the center. Otherwise I was thinking 2s seriesed . I did order 2 seaking v3 180's so I have options. For now I'm stuck what to do
--Albert Einstein
I want to kiss the guy who invented this putty it sure makes building these thing so much easier
--Albert Einstein
Probably going to tuck the servo here. That will be another night
--Albert Einstein
--Albert Einstein
Well it looks like I'm on a roll here and today is my first day of vacation !
In order to save weight and to try something new I am going to make the servo mount with lexan . The servo will be double sided tape to the mount followed up with two zip ties.
--Albert Einstein
I'm really liking the design of the new 180's. I already have a idea on how to make a cap cooler for it as if it needs it because the caps are submerged in the cooper compound stuff . If your caps do go not good so I will show a pics of the little mod later. And I already found another use for the putty !
--Albert Einstein
Ok I got the servo linkage setup in , may as well putty that too
--Albert Einstein
I decided I don't like the servo mount no more. This putty has me lazy
--Albert Einstein
Went ahead and did it the easy way and life is good again . A little cutting , a little braising , a little filling , a little sanding , a little drill and tappity-tap tap and bam
--Albert Einstein
Up next a hinged lexan battery hood to keep them in place
The chickens are clucking !
--Albert Einstein
