Cheeta the Cheeeze Build
  • rearwheelin
    • 1941
    Pleasure was mine ! It was a great opportunity to get on with some new ideas Look forward to seeing it in the water !
    --Albert Einstein
    • riptide1
      • Feb 2011
      • 241
      Took her out for the maiden run today. Firstly, this is by far the best handling boat I've run. It tracks straight and goes into a tight turn at full throttle. The top speed on 5s was good, but still leaves much to desired. The boat rtr weights 11lbs even. The CG was set at 30% or 10.5" from the transom. The prop was an x447 2 blade. Temps came back pretty hot. I definitely need to change from the 6.5" Castle bullets, they came back at 180 degrees F. The motor was at 150 degrees and the batteries and ESC were at 130 degrees, so that leaves me no room to prop up without changing the setup. It seemed like the prop wasn't always hooking up. I don't know if I should raise or lower the strut.
      • riptide1
        • Feb 2011
        • 241
        • riptide1
          • Feb 2011
          • 241
          to run my lightweight 4s lipos I'm going to add 10oz of lead to the transom, but I will still be dropping 10oz compared to the 5s lipos.
          IMG_20140706_214126_171.jpgIMG_20140706_214721_945.jpgIMG_20140706_214508_493.jpgIMG_20140706_214915_201.jpg
          • rearwheelin
            • 1941
            Glad it did my job ! .... Minus the sponson mod
            It looked very good in the vid for a maiden
            I know exactly what hardware I will be running on my Team Believer that I will be building after the Titan now !
            --Albert Einstein
              I wanted to say something earlier on in the thread but decided to keep my opinion to myself. I think you now know in the back of your mind why it's running hot like it is. That's not quite enough motor for that hull. The castle 6.5 connectors are excellent connectors and I use them on all of my stuff. My connectors never run hot but I haven't under motored and over taxed any of my power systems yet. That hull does good with a 1717 or maybe a neu 1527. A 1518 just isn't enough in my opinion and judging by the temps.
              • keithbradley
                • 3663
                I watched the video.
                Honestly, if you showed me that video (actually, even if I didn't even see it, but just heard the audio), I would assume that it's coming back with components that are hotter than you would like. Have you checked the data logs? I imagine it's pulling a lot of current, likely even much more in small spikes that you won't necessarily see in the logs.
                There is excessive lift on the transom. Either your strut setting is causing this, or the hull has a hook toward the rear. If you can get this issue corrected it will run cooler, and you'll pick up a considerable amount of speed.
                www.keithbradleyboats.com
                • riptide1
                  • Feb 2011
                  • 241
                  Keith, here's the rear ride pad profile after the hull mod. I will check the strut angle. Do you think I should cut down the 6" rudder or that the large hardware is a problem, causing the lift? What CG does this hull like?
                  • riptide1
                    • Feb 2011
                    • 241
                    • riptide1
                      • Feb 2011
                      • 241
                      I was looking at hull mod pics to try to figure out if the rear outside strakes look like mine. To me it looks like the whole rear after the last step is angled to cause hook or nose diving. While I'm studying this I noticed how much negative Tigueman has in stinger. I ran neutral so the next thing I will try is to give it 2 degrees of negative strut angle.
                        • 9479
                        this thing should really scoot with that motor after you make a few adjustments!
                        can't wait to hear the results :)
                        • riptide1
                          • Feb 2011
                          • 241
                          I adjusted the strut before this second run. In the pic you can see the slight negative adjustment. I think I was actually running positive because the transom isn't quite at a 90 degree angle to the running surface and that is what I was using as reference initially. With this change I experienced a huge difference in temps and runtime. Next run I have a shorter rudder to try, it's a 60/90 straight blade cut down significantly for SAW racing. https://drive.google.com/file/d/0Bxp...it?usp=sharing
                            when i used a short rudder on mine, it would randomly flip around if i tried to turn even just a little. hopefully you have better luck. Is the speed any better?
                              • 9479
                              [ATTACH=CONFIG]117718[/ATTACH][ATTACH=CONFIG]117719[/ATTACH]
                              Good job man!
                              • rearwheelin
                                • 1941
                                Needs a 4060 2040kvTP motor with a 447x 3 blade
                                --Albert Einstein
