On to the next build. I have a 42" Seaducer that was purchased by a club member in 2008, but was never run. I plan to set it up to run "T" class with it. I will be using a Castle 2028, Castle HV 200amp, and I "think" I will run it 10s2p. I might run 8s2p as I run that same set up in a Backlash I have.
So, there are many issues to work out. Starting mostly with where do I fit the batteries! I have pondered cutting out the plywood rails between motor and the aft of the boat and placing the on either side of the drive shaft. I am open to ideas and suggestions.
What is the COG recommended for this boat? I read through the instructions that came with it and it talks specifically where to place all the hardware for a gas boat, but not what the COG should be.
Another odd thing is the shaft runs through the back of the hull for the strut with a nice gap for adjusting, but no water tube installed to keep the water from coming into the boat? Is there something I should know about the way the gas boat people set up these boats that would explain this to me?
I am heading out to the garage to pull the 2028 motor from the backlash and start to position that and the ESC and will take some more pics.
