How the inside look? Is everything installed yet?
Objective - Triple Digit Mono
Very nice Joel, that thing looks like it's flyin' just sittin' on the stand!
I don't think you'll have any problem breakin' the hundred...
That looks absolutely amazing!!! Keep up the good work!37" Fightercat Shocker powered by Neu 1530 on 10S
Very nice !"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
I'm pretty sure you will get your objective!Beautifull boat and work! Congrats GillGO FAST AND TURN RIGHT !
www.grsboats.com.br
Man Joel, I have showed this build to a few people and everyone says the same thing, Beautiful!! She is a work of art inside and out, can't wait to see her run, in person I hope!!
Your other new BIG mono is a beauty also, maybe theme your next build after her since you are into monos now
On board vid of Joel's other mono
Subscribed !! really nice Joel top shelf !!!! I think you would be better off with round bottom struts. the flat bottoms strut will cause lift, might want to stuff at Hi speed , I had a problem on a twin gas 50" apache, running the struts close together, the boat would hop to much in the turns , I know you just want to go Straight LOL anyway great job, Chris
Thanks Chris. I'm starting with the flat bottom struts just for that reason. With all the weight in this hull, my thought is it might need more lift. My twin 59'' Outerlimits Mono had a hard time getting up on top of the water. If it is too much I'll swap them out for the round ones. Thanks for the input, we will see how she does. I'm thinking the props you resurrected for me might work well with this one. And yes....not concerned with turning. I only need to turn around and backup the last pass...Originally posted by dasboata View PostSubscribed !! really nice Joel top shelf !!!! I think you would be better off with round bottom struts. the flat bottoms strut will cause lift, might want to stuff at Hi speed , I had a problem on a twin gas 50" apache, running the struts close together, the boat would hop to much in the turns , I know you just want to go Straight LOL anyway great job, Chris
Looks awesome how is it running a mono that fast? The sound-factor must make it that much better to drive.
