Delta Force 29 newbie build
  • danallen
    • May 2014
    • 55
    Greetings everyone! I thought I would post up my first steps into non-rtr boating. I realize that this is pretty simple stuff for most of you guys, but it was fairly intimidating for me.
    Some history:
    A couple weeks ago I crashed my Aquacraft Revolt 30 pretty hard into some rocks and severely damaged the hull.
    Thread about it here: http://forums.offshoreelectrics.com/...-advice-please
    Anyway, I decided to buy the DF 29 hull, and a few other associated items from our host. (Extremely pleased with OSE's service by the way!)
    The idea was a budget build using the hardware and electronics from the Revolt in the new hull.
    Equipment specs:
    Delta Force 29 hull
    Aquacraft Revolt hardware (grimracer?)
    Aquacraft 60amp esc
    Aquacraft 3656 1800kv 6-pole motor
    4s 5100mah lipo
    Octura x445 prop
    Savox 1258tg servo (I know it's overkill but I had it laying around)
    Airtronics 92524 reciever and MT4S transmitter
    On to the pictures! ...
    First a couple shots comparing the size difference between the two hull. (The DF29 is .5" shorter and about 1" wider than the Revolt.
    DF29 - http://forums.offshoreelectrics.com/...ild&highlight=
  • danallen
    • May 2014
    • 55
    Having never built a boat before, I wasn't sure where to start. I decided to begin with simply marking a centerline on the transom as a reference point for the hardware.
    And drilled my first hole in my virgin hull.
    After a couple of hours of carefully measuring everything... and a few wild guesses thrown in for luck, the stern was starting to look near completion.
    • danallen
      • May 2014
      • 55
      Well, I had no idea where to mount the electronics so off to google for some info (because the internet is always right. ...right?) I read that most mono hulls seem to like the cg around 28%-30% so thats what I shot for. Pretty much I just set everything in place and slightly adjusted everything around until I was happy with the weight balance. With my 4S battery all the way back the cg is about 25%, but I ordered 350mm battery tray with the hull, so there is plenty of room to move it forward to adjust the cg.
      • danallen
        • May 2014
        • 55
        At last I was nearing completion. I finished a few things, slapped some stickers on the hull and took a few completion pictures.
        • Luck as a Constant
          Make Total Destroy
          • Mar 2014
          • 1952
          looks mint
          • danallen
            • May 2014
            • 55
            Unfortunately, I have only been able to run the boat twice since building it. Very busy with work, but such is the life of a military man.
            It is fast! quite a bit faster than my friends stock revolt. It accelerates great and turns great, but at high speed I cannot hold full throttle in a straight line for more than a second or two or it wheelies out of the water. I have since adjusted the prop down a few degrees, hopefully that will settle it down some (yet to be tested).
            Also, I've made a couple of upgrades/changes since building the boat that I thought I'd share.
            I sold the AQ 60a ESC and ordered a seaking 180a v3 from our host to replace it. Also, the Savox servo got removed to serve in my Tekno SCT, and a Hitec HS-5646WP was installed in its place. Lastly I replaced the 92524 receiver with an RX-461 that has telemetry so I can keep better track of motor temps while running. Unfortunately, the Seaking 180's bec only goes to 6.0v and I'd like to run at 7.2v so I may add an external bec in the future. I'm also toying with the idea of buying a receiver box, as opposed to shoe glueing by receiver, cap and maybe ext-bec to the hull like I have now, any recommendations?
            One last question; What timing does the AQ 3656 1800kv 6-pole motor like?
            Stay tuned for the next update when I get the new ESC installed and get some testing done.
            Bye for now!
            -Dan
            P.S. a pic of the new servo and receiver (the small nylon tie on the motor is holding the telemetry temp sensor) minus ESC:
            • 785boats
              Wet Track Racing
              • 3423
              Nice clean build there Dan.
              But one thing worries me. Having the motor mount just glued to the hull on its own can usually result in it tearing away in a good tumble. The battery tray too.
              I usually epoxy a piece of 1/4" carbon fiber tube from the transom, against the motor mount, & up to the front of the battery tray. This bonds everything to the hull a lot more strongly. And it also makes the hull & motor mount much more rigid. Sand the areas that epoxy will contact, & wipe it down with Acetone to get rid of the waxy film in the hull. Nothing sticks to that very well. Works in cats & hydros too.
              Here's a couple of pics to give you an idea.
              • danallen
                • May 2014
                • 55
                Thanks for the tip, Ill look into some CF tubes. Is there a certain brand or strength I should look for? Or just any 1/4 cf tube.
                Also, Do you epoxy the whole thing or just every couple inches?
                • 785boats
                  Wet Track Racing
                  • 3423
                  No special brand. A good thick wall or even a rod. I generally salvage my sons broken arrow shafts & use them. If you have a local hobby shop, they usually sell carbon tubes. Especially if they sell kite making stuff. I've even used tubes from Hobbyking. Plenty strong enough.
                  I Epoxy all the way, with plenty on the engine mounts & battery tray.
                  Be sure to sand the rods with some 240 grit, or so, paper too.
                  • danallen
                    • May 2014
                    • 55
                    I bought some 1/4" CF tube at the hobby store and installed it today. The motor mount is much more sturdy now.
                    • 785boats
                      Wet Track Racing
                      • 3423
                      There ya go.
                      • danallen
                        • May 2014
                        • 55
                        Today I got my new ESC installed. I also replaced the esc/motor 4mm bullets with 6.5mm bullets. I honestly never felt any heat after a run with the 4mm ones, but I don't want a problem in the future. Especially since I'm considering upgrading to a bigger motor, but that topic is for another time.
                        I did some googling and found that the stock AQ 60a esc has its timing set at 11. So I set the timing on the Seaking to 11.25, it was the closest setting available. I suspect AQ knows their motors better than I do, so why change it.
                        Next, I'm thinking about a new motor. The castle 1515 2200kv is the one in sight right now. We'll see, I would like to run the boat as is a few times and learn a bit more about trim/strut adjustments before I put in a bigger motor.
                        Thanks for reading.
                        -Dan
                        Edit: I forgot, I also read that it was a good idea to pour some epoxy into the tip of the bow. So I did that as well. Not alot just about 3/8".
                        • cuppa
                          • 46
                          Nice build Sir
                          oh galar da - lle oedd i roi fy ngeiriadur Cymraeg
                          • 785boats
                            Wet Track Racing
                            • 3423
                            Dan.
                            Cuppa is 100% right.
                            For a first build you did everything pretty much spot on.
                            Congratulations on a job well done.
                            Of course you do understand that videos are a compulsory part of the deal, don't you.
                            • PowerDemon
                              • 353
                              That is a fine build! Especially as your first one. Congrats!
                              37" Fightercat Shocker powered by Neu 1530 on 10S
