Scratch 36" DeepVee
  • Viking
    • 133
    Scratch 36" DeepVee
    Good Morning to all;
    I am new here, I have a build project someone might be interested in. I drew up a set of plans and then built a 36" boat based on the Apache DeepVee race boat. With the hull fiberglassed I proceded to make a mold. The mold is waxed and ready to make a boat, but it is raining here. I don't spray gelcoat in my basement workshop because it smells up the whole house. Maybe tomorrow. I have a slide show of the build on my web site at http://www.dickieeng.com/Viking%20slideshow/index.html
    Comments welcome;
    Viking
    That Viking www.How2RC.com PULSO
    Home made 36" DeepVee 50mph
  • C.Smock
    • 213
    looks good! what kind of setup are you going to run.
    67+ MPH N2 MONO
    www.atlantamodelboaters.com
    TEAM FLIGHTPOWER
    • Viking
      • 133
      I have some experience with brushed motors but would like to try a Brushless system on this one. A single prop set up. I Don't know how to choose a motor .
      My 50" Apache (nitro) swings a 2" prop, my guess is this boat will need something in the 1.5" range to move it.
      • DISAR
        • 1072
        Nicely built hull. I have a 36" mono (Delta force) and I can recommend the following setups:
        a) Motor: KB 45 8xl or Feigao 9XL with water cooling(I tried both of them and working fine)
        Lipos: 2 X 2s (7.4V) in series = 4s1p (14.8V)
        3/16 flex shaft and propeller shaft
        Strut and rudder you can find something in OSE site (mine were bought from UK)
        Propeller: Graupner 2317.45 or Octura 645,646
        ESC: 200a (you can buy the Mystery one and coat it with epoxy 3M DP270 to make it waterproof and then make a cooling plate for cooling, please check the "Tips" page in OSE main site)
        or You can buy anything else over 150A (waterproof and cooling are essential)
        Speed: +40 mph
        b) All same except the Lipos 2 x 3s in parallel 3s2p (11.1V) and propeller Graupner 2317.48
        Speed: around 30 mph
        The above setups are with the minimum budget and are actual setups that I use.
        They are not the best ones and the fastest. Based on info from very experienced members which you can find around here but I will give the resume', the following will give you better speeds:
        Motor: 800 KV , Lipos 8 cells 29.6 volts (2x4s in series), Prop: 55mm OR
        1350 Kv, Lipos 8 cells, Prop: 46 mm
        You can workout anything between the two motor Kvs only the prop. needs to be calculated.
        OR
        Motor 1100-1800KV, Lipos 6 cells 22.2volts (1x6s or 2x3s in series), Prop:51-39mm
        http://www.rcfastboats.com/
        • Viking
          • 133
          Many thanks
          That certainly is a lot of valuable info. I have been looking at the Feigao XL and didn't know where to start with the wind. Thanks for all that info. If it will stop raining I will lay up a hull tomorrow, but it won't come out of that new mold for a few days, so middle of the week I should get a look at it. In the mean time I'll work on the deck.
          • Viking
            • 133
            Progress
            Friday; I sprayed 2 coats of PVA into the mold. PVA (poly vinyl alcohol)is mold release wax , wax in suspension in alcohol. it is sprayed with a paint sprayer at high pressure to insure small particles. It cleans up with water ! When I got the mold off the plug ( original boat) both pieces came clean with the garden hose and a paper towel and the spray gun cleans up with water too.
            It is quite hard to get a good wet coat of PVA, some one called it a black art. I agree but, the gods were with me and I got a very nice job.
            It's Saturday;
            I sprayed two layers of Gel Coat (white) into the mold and followed it with 3/4 oz matt in boat resin, in an hour the mold was hot. Everything went well.
            There is a slide show of this build on my web site , here is a link to the slide show
            More fiberglass tomorrow and then the long wait to get the boat our.
            • Viking
              • 133
              Glass lay up
              Sunday; More fiberglass, I put another layer of 3/4oz fiberglass matt in the hull in boat resin. I waited about an hour untill the resin was tacky but didn't stick to my finger then I layed up a layer of fiberglass cloth which will be the inside of the boat. All went well.
              Now the hard part, waiting 5 days for the hull to cure and shrink slightly so it will come out of the mold with a minimum of damage to anything. This is the first hull out of a new mold, I don't expect it to be perfect.
              • ED66677
                • 1300
                I'm always impressed by those who start such a project!!!
                Really nice job!
                Emmanuel
                • Ocean Racer
                  • 502
                  Any updates?
                  Failure is the First step to SUCCESS
                  • Viking
                    • 133
                    Success !!!
                    I got the boat out of the mold today and it came out nice. So nice in fact that I am prepping the mold for another attempt soon. I even have photos.
                    • rockwerks
                      • 772
                      very nice!
                      an RC rock crawler lost in a sea of boat parts.........
                      • blakybob
                        • 126
                        How much does it weigh? What are your plans for the deck? You have put alot of time, talent, and thought into this for sure. Looks good!!!
                        Blake
                        • Viking
                          • 133
                          This gets complicated, the hull is on the lines of the Apache ocean racer, before I even got the plans drawn my son says leave the bow up, I am looking for a boat to make into a sport fisherman, so I did. I plan to cut the bow down on this one and build an Apache like deck and cockpit with driver, navigator and Motor hatches, make a mold, etc. Then pull a hull out for my son, with the high bow. I got carried away with the resin the hull weighs 2.5 lbs. Do you have any Idea what a 36" hull should weigh?
                          Sure would have been cheaper to buy a boat, except I couldn't fing anything I liked at 36". It came out great, I am really pleased.
                          John
                          • Viking
                            • 133
                            The Deck
                            Hi
                            I have the deck mock up almost ready for making a mold, and the hatch too.
                            I have another boat curing in the mold. I am crossing my fingers that this one is lighter than the first. photos soon
                            • Ocean Racer
                              • 502
                              So what does it look like?
