Kev's Daytona 37
    • 7651
    Originally posted by Fella1340 View Post
    That's bad news, I think your going to be sanding back down to primer, unless somebody knows of a chemical stripper to use. Some lacquers and enamels combinations are worse than others. A good idea is to spray the paint on the back of a plastic spoon to see reactions and gives you a good sense of what the colour will look like. Airbrush guys do it all the time. Good luck, wish I knew an easy answer.
    Smart Strip guys, Savage Skidoo used it on the SprintCat http://www.homedepot.ca/product/smar...aerosol/980985
    • boredom.is.me
      • Jun 2009
      • 595
      ImageUploadedByTapatalk1398532330.493650.jpg ImageUploadedByTapatalk1398532339.509771.jpg ImageUploadedByTapatalk1398532353.960963.jpg ImageUploadedByTapatalk1398532363.829693.jpg ImageUploadedByTapatalk1398532511.557414.jpg
      • boredom.is.me
        • Jun 2009
        • 595
        Thanks for that. Hmmm...should I? I want to.
        • Fella1340
          • May 2013
          • 1025
          That's going to look very cool. Nice use of different materials.
          • Fella1340
            • May 2013
            • 1025
            #35
            Anything happening here Mr. Boredom? I am looking forward to seeing your design go together.
            • boredom.is.me
              • Jun 2009
              • 595
              #36
              I've been checking to see if the brackets have arrived........I just got a shipping notification. -crossing GLB off of my list.
              • boredom.is.me
                • Jun 2009
                • 595
                #37
                My computer has been down so I have not been active on any forums. I just got it to full strength yesterday.
                As for the boat, nothing new. I've been waiting on the parts. I did try to find the Smart Strip, but it is a Canadian thing eh. There is Citri Strip though, which is half the price and the more promising option from Home Depot.
                • boredom.is.me
                  • Jun 2009
                  • 595
                  #38
                  I finally got the brackets! It is great to see everything put together. It sucks to see that I screwed up somewhere. The motor and top plate sit way to high. You know the saying "measure twice, cut once". Well I'm pretty sure I measured way more than twice, but mistakes happen. Aside from the side rails, everything is perfect. I'll see if I can grind or cut them shorter some how. If not, I'll just order a revised version the rails.
                  I'll get pictures a little later.
                  • boredom.is.me
                    • Jun 2009
                    • 595
                    #39
                    ImageUploadedByTapatalk1400559174.640840.jpg ImageUploadedByTapatalk1400559186.538549.jpg ImageUploadedByTapatalk1400559197.239279.jpg
                    • boredom.is.me
                      • Jun 2009
                      • 595
                      #40
                      I knew I didn't screw up the design. I used the wrong part in the final file... What I got was the previous 15 degree rails.
                      • Fella1340
                        • May 2013
                        • 1025
                        #41
                        That looks great, I didn't realize having stuff custom made was an affordable option. The esc sits great in there and really tidy with the braided sleeve. The sleeving can be a pain in the the butt! Your a lot further ahead then me. I found out there's a lot more resin than cloth in the extension piece for the rudder. Should fix up Ok. I really like how it's coming together.
                        • Fella1340
                          • May 2013
                          • 1025
                          #42
                          Anything more going on? Has she hit the water yet?
                          • boredom.is.me
                            • Jun 2009
                            • 595
                            #43
                            Kev's Daytona 37
                            I finally got around to actually running this thing. The original motor mounting plate broke so I fabbed up this 1/8" aluminum plate.
                            • boredom.is.me
                              • Jun 2009
                              • 595
                              #44
                              Just thinking about the second hull... I was going to spray the boat gunmetal, with a white "waterline", and "anodized" red where the tape is. But after seeing my original post, I think I'll go back to that.
                              ImageUploadedByTapatalk1462492485.447360.jpg ImageUploadedByTapatalk1462492496.078879.jpg
                              • boredom.is.me
                                • Jun 2009
                                • 595
                                #45
                                I've also been playing around with the mount since I can now cut aluminum.
                                The mount furthest from the black one is the newest. I did get rid of the integrate ESC housing since I do not have the newer T180. The overall width, not including screw heads, shrunk from 75mm to 65.35mm assuming that a 1/8" thick material is used for the side frames. The last picture would be a little jig that will be used to drill the sides. It works with both front and rear parts. I do not know what to make the side frames from though. I could go aluminum, cf, or g10.
