working over my mean machine ....
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    #46
    I agree it does look quite a bit slower than it should be running.
      Make Total Destroy
      • Mar 2014
      • 1952
      #47
      It almost looks like it's running with the lvc kicked in
      • gsbuickman
        • Jul 2011
        • 1292
        #48
        Sorry guys let me clear up some of your confusion, sorry .
        It is a 2350kv / m445 prop on 2 thunder power 3850mah 30/60c 4s1p cells in parallel, s OK its basically 7700mah 4s2p. The rudder is a 4 1/2" swing away, that hangs 2 1/2" below the ride pads.
        CharacteristIcs of a stepped hull is that it snaps turns at speed like it's on rails, whi c h it does at lower power/ kV like the 2s x 2 4s series and 2030kv that was in it.
        Its a lot faster than it was before, way faster than the 35mph traffic In the street. I do realize I need a deeper rudder with the higher power setup. I was testing my turn radius when the power alarm on my r radio started beeping.
        I do need a better camera angle, like a side view that shows a full speed pass, rather than a front diagonal. I was filming off a tripod, so I couldn't track with the boat. I also need to film at a larger pond, this is just the pond I use for shakedown test runs.
        As soon as I get my new 200A ESC I ordered, I'll shoot some vids at Julius kleiner park, and I may give my venom 5000mah 25c 5s1p packs a try in parallel.
        • gsbuickman
          • Jul 2011
          • 1292
          #49
          I almost forgot . The hull is 29" long, and the balance point I s set a th 30%, which I s 9 1/4" from the rear, or 19 3/4" from sponson tip. After notching the slot in the strut the prop is 3/16" above t he ride pads.
            • 5660
            #50
            "... I do realize I need a deeper rudder with the higher power setup. I was testing my turn radius when the power alarm on my r radio started beeping. "
            In my opinion you won't realize the full potential of this hull's turning ability until you install a longer rudder, you will be amazed at the difference it makes , also the threshold between spinout and no spin out is surprisingly narrow.
            A 5" rudder may do the trick, I had the Speed Master http://www.offshoreelectrics.com/pro...d=ros-spdr-001 and no more spin out.
            BTW, vid. is nice, like your location
              Make Total Destroy
              • Mar 2014
              • 1952
              #51
              Yeah maybe it's the angle of the camera playing tricks. Your strut height sounds right, good prop choice... Etc
              The rpm still sound a bit low to me but if you can get a different vantage point Thad be great.
              Most of us in here have/had mean machines including myself, so we know what it should look like at full throttle
              • flraptor07
                • Aug 2013
                • 2451
                #52
                Did you say M455 prop? that's 55mm 1.4 pitch?
                • gsbuickman
                  • Jul 2011
                  • 1292
                  #53
                  It's a good ol' m445 w/ a 1\16" back cut, to cut down on the low speed amp draw & gives it a Lil' more rpm
                  1.4 x 1.77" = 2.478"
                  I also like the Octura 440/3 blade on this setup, with 4s & 5s. A 1.6 pitch x645 on 5s is smokin' fast with this hull, or the sprint cat, but squirrley and hard to handle
                  • flraptor07
                    • Aug 2013
                    • 2451
                    #54
                    I also like the Octura 440/3 blade on this setup, with 4s & 5s. A 1.6 pitch x645 on 5s is smokin' fast with this hull, or the sprint cat, but squirrley and hard to hadle
                    In post 48 it says M455..
                      • 5660
                      #55
                      lol... m445 says post #19
                      • gsbuickman
                        • Jul 2011
                        • 1292
                        #56
                        Typo
                        • gsbuickman
                          • Jul 2011
                          • 1292
                          #57
                          Here is Jorn's 29" sprint cat. He's running a 4040 1800kv on 6s, pulling a 440/3 prop.
                          After this he swapped in a 4074 2000kv mill, and a x645 prop & broke 75 mph . Jorn races FE across the pond. I follow his vids :-) .
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            #58
                            Why in the heck are we watching some European guys Sprintcat?
                            • flraptor07
                              • Aug 2013
                              • 2451
                              #59
                              I'm not sure I'm getting what it has to do with "Working over my Mean Machine" ????
                              • Fella1340
                                • May 2013
                                • 1025
                                #60
                                I'm thinking he just wanted to share a video with us, it's his thread after all.
