Time for me to build my first saw boat
  • Darin Jordan
    • 9446
    #46
    This is very, very nice work.
    Darin E. Jordan - Renton, WA
      Thanks man! This means alot coming from you! :)
        I have a better idea on the hatch hold down. I was gonna use hatch locks. I don't like how big a Hole I have to drill to make them work and weakening my hull which I don't want. I was recommended to go with hatch bolts. I don't like the idea of having to fumble with an Allen wrench. So my idea is some knurled aluminum thumb screws.
        • Rocstar
          Joel Mertz
          • 1536
          #49
          Thumb screws work.
            Originally posted by Rocstar22 View Post
            Thumb screws work.
            Where did you get those? I like them.
            • Fella1340
              • May 2013
              • 1025
              #51
              The stuffing tube and motor mount turned out first rate, nice job. Excellent work on the servo mount to. Your really outdoing yourself on this one. I am almost ready to start my build thread, been a long time coming and should have it up within a few days, if not today. Keep up the top notch work!
              • Rocstar
                Joel Mertz
                • 1536
                #52
                I have a bunch coming in on Monday. I also have the rubber washers and foam seal. PM me what you need and screw size and we will see what we can do.
                  Thanks man. I learned a few more tricks since I built the cheetah. I think I wasn't as into building the cheetah as this boat. Not saying the cheetah isn't build well... It is. I just got more excited after driving the cheetah a few times. Guess I was a little depressed because I wrecked my geico. Was nervous about doing it again and destroying a much more expensive boat. I've found a safer place to run since then and learned not to do what I did again lol. I've also had more energy here lately and I usually don't work in my shop during the week. I was hoping to have this thing done this weekend but the hatch locks ordeal is setting me back. I'm going to run to this badass hardware store we have 15 mins frm my house to see if they have some stuff to do what I'm planning on with the hatch so I don't have to wait. Still gotta get by the hobby shop and grab my castle connectors. Probably do both tomorrow morning.
                    Time to drill the hatch for my bolt setup. Never drilled a hatch before and I didn't wanna screw it up. So I came up with my own way of making where to drill. I'm sure yo can figure out what I did by the PUC.....
                    • Rocstar
                      Joel Mertz
                      • 1536
                      #55
                      Next time just measure and mark holes to be drilled on the hatch keeping in mind that the thread bosses have to sit in the hatch lip. Then with the hatch on, drill your holes through hatch and hatch lip.
                        I didn't trust myself holding the drill straight or maybe slipping and scratching it up lol.
                          Hatch is done. I put the foam Seal on. I have some temp hatch screws on there for now. The motor is mounted. Wires shortened on the esc and motor. Blue loctite on all the screws. I'm laying the straps and velcro for the batteries right now while the epoxy dries on the ubec. Servo is mounted. Rudder and linkage done. Two part foam floatation in the hull and hatch is done. Basically I have to run the cooling lines and finish hooking up electrical. Almost done!
                            I had some issue with the cooling lines and steering linkage getting in the way of each other. I had to recent the steering linkage and run a short piece of brass tubing to the cooling bulkhead fitting. I didn't want to take the chance of it binding. Its good now but took a while to get it sorted. All I have left is the power connections on the esc and its done. I decided to call it quits for the night. Here's some pics.
                              I'm putting foam in the hatch. I don't know why because if it comes off its going to take some of the hull with it. Lol. I guess just in case..... You never know.
                                Looks good, Maybe run some CF cloth over the hatch and seal the foam in after leveling. Looks good and adds some strength to it.
