Mark's Mean Machine
  • Fella1340
    • May 2013
    • 1025
    Looking nice.
    • SloHD
      Slow Electric Addict!
      • Apr 2013
      • 337
      May I ask where you get the motor mount from? I like it a lot...
      • Rocstar
        Joel Mertz
        • 1536
        It's an MBP mount, Rocket City carries them.
        • SloHD
          • Apr 2013
          • 337
          http://www.rocketcityracing.com/electric/
          Thank you! Looks like that one is out of stock...
          • Rocstar
            Joel Mertz
            • 1536
            Motor mount and tube in place...
            • kenrid
              Fast Electric Enthusiast
              • Dec 2012
              • 33
              Subscribed.
              FE30, Kintec Pursuit, Revolt 30, ML GP400 V2, Blackjack 29 (RIP), HK Outer Limits
              • gsbuickman
                • Jul 2011
                • 1500
                Joel,
                Looks good so far - agreed that the top deck overhang yields a small landing pad for the hardware feet. I ran into the same sitch in a recent MM build with Spd hardware. Had to lengthen the strut slot as well to get enough vertical adjustment to keep the prop from being oversubmerged.
                [ATTACH=CONFIG]112273[/ATTACH][ATTACH=CONFIG]112272[/ATTACH]
                I agree with Tim that a decent amount of rudder is key to avoiding spinouts - I like the Spd .21 because it's ultra-long and can be trimmed to suit. Then again there's other ways to skin (turn) a cat : (I did this to my beater MM for the L + R turn Offshore course at Winter Warmups). Worked great but lots of drag kept the speed down a tad
                [ATTACH=CONFIG]112274[/ATTACH]
                Thanks for the tip PC
                I was wondering about the slot in the strut, My meanie is running a UL-1 2030kv motor, m442 prop, turnigy ESC & Rev-Tech 6000mah 28-45c 2s bulletpacks in 4s series.
                I started with the strut parallel & level with the sponsons, then started raising the strut. It maxed out at 3/8" above the sponson's, but it was still plowing water fighting to plane out so it wasn't enough. I just took a rat tail file and extended the slot in the strut another 3/8" , to the start of the knife edge on the strut. Now I have some room to play with it. Thanks
                • Rich
                  • 581
                  Taking some advise and swapped out the rudder for a Speedmaster 21. It's way too long, but the water pickup is high enough that Mark can trim as needed.
                  I said the same thing when I put that rudder on mine, but I got to tell you it helps a ton with spin outs. I did trim it a little til I saw no gain in performance. This hull digs a long rudder.
                  • Rocstar
                    Joel Mertz
                    • 1536
                    Laying out where the ESC, battery trays, and servo mount will sit...
                    • gsbuickman
                      • Jul 2011
                      • 1500
                      Heya Rocstar
                      What did you use for hatch hardware & a seal ?. I am always looking for alternatives to taping my meanie
                        Hey, that's what I call a real "Mean Machine"---inside and out! Looks fab!
                        • younglings
                          • Jan 2014
                          • 31
                          very nice job !! you are a cyborg ?
                          • Rocstar
                            Joel Mertz
                            • 1536
                            Originally posted by gsbuickman View Post
                            Heya Rocstar
                            Keith sells a kit.
                            I might have enough here for another hull, I'll check.
                            • Chrisg81983
                              • Jul 2011
                              • 1585
                              Heya Rocstar
                              There are many ways to make hatch bolt systems. You can find many build threads here on OSE that explain it very well i know I have three thrrads myself. I like to take a 25mm x 13mm piece of cf plate and epoxy under the hatch. When dry I drill and countersink m3 bolts in them. I then put hatch on hull tape in place and drill the deck of hull itself using hatch as a guide. Finally gue a treaded piece of aluminum stock under deck where hole is. Bow you will have a flush clean look when hatch is bolted down still being able to tape if needed. other ways will work I just find this to be the cleanest and most effective it take some time to do. taping is always a good idea my head bolt systems seal the whole 100 percent and I still tape
                              Joel boat looks great sorry for jamming up thread hope you don't mind. take everyones advice on the long rudder it will make a huge difference. I have built about 5 or 6 MM and they all loved long blades.
                              • Rocstar
                                Joel Mertz
                                • 1536
                                Working on the finishing touches for this one, and will be shipping her out soon. All the water lines are in and I notched the battery trays for use with Velcro straps. ESC plate and servo/RX mount are in place.
