What is a "flooded tube"
  • Varooom
    • Nov 2013
    • 97
    Ya, nubie question,
    I have been reading many pages of builds. I see a flooded tube mentioned often.
    Could someone please explain what it is compared to a regular stuffing tube "I have a Revolt".
    And what are the pros, cons?
    thanks for your time,
    Varooom
    I don't intend to write a tome, but simply a flood tube is a large diameter chamber surrounding the regular stuffing tube, usually on a mono. It provides a lot of adjustment of the strut up and down, critical to many boats. Without one, possible vertical adjustments are very minimal.
    Here is a photo of the business end of the tube. Inside the boat the tube is sealed around the brass stuffing tube so there are no leaks.
    • Varooom
      • Nov 2013
      • 97
      Thanks Fluid,
      I assume a strut, not a stinger, must be used with a flood tube?
      thanks again,
      varooom
        Most stingers have a limited amount of vertical adjustment, so you could use one. But a strut would be "better".
        • RaceMechaniX
          • 3024
          Take a look through this thread: http://forums.offshoreelectrics.com/...-Target-100mph
          It should give some better insight with pics.
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • Varooom
            • Nov 2013
            • 97
            Wow, thanks Tyler,
            That really clears up the flooded tube for me.
            Also excellent build thread.
            Thank you,
            Varooom
            • RaceMechaniX
              • 3024
              Glad it helped.
              Tyler Garrard
              • urbs00007
                • 857
                how about epoxying a large brass tube in the bottom of the transom sticking into the hull about 1 " or so. then run a flexible rubber hose or boot from that to stuffing box. same thing as tube, but much easier.
