Even better...will end up trying 2 - 4S packs up front and the 2 - 2S packs on each side of the motor (pushed up to the forward truss)...will still make provisions to run them ALL up front if need be....
M&L GP400 Next ? Help
Kent, with that many connections dont you worry about connection problems. Also every connection regardless how good is a bottleneck (impedence) is it not ? ... I'm going with 2 6S 3500mah 40-80c in para for heat running and 2 4-5s 6000mah 65-130c in series for SAW....the weight diff tween the setups is minimal, so getting CG will be no prob.....I have decided im going 1527 1.5d 1500kv instead of the 1Y 1250kv ..I think having 7000mah of fuel should be enough for a heat using that motor and the extra KV will give me what im lookn for in a sport SAW setup.... DJOriginally posted by HOTWATER View PostEven better...will end up trying 2 - 4S packs up front and the 2 - 2S packs on each side of the motor (pushed up to the forward truss)...will still make provisions to run them ALL up front if need be....Tunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf Dragboat
The easy answer to why I am going to run 2- 4S and 2-2S packs is because I have them...will possibly buy some 6S packs later when $ is better...; )Originally posted by olwarbirds View PostKent, with that many connections dont you worry about connection problems. Also every connection regardless how good is a bottleneck (impedence) is it not ? ... I'm going with 2 6S 3500mah 40-80c in para for heat running and 2 4-5s 6000mah 65-130c in series for SAW....the weight diff tween the setups is minimal, so getting CG will be no prob.....I have decided im going 1527 1.5d 1500kv instead of the 1Y 1250kv ..I think having 7000mah of fuel should be enough for a heat using that motor and the extra KV will give me what im lookn for in a sport SAW setup.... DJ
Kent, I can totally understand that !...Ive been doin some Lipo research yet again and have been reading some good reviews on these http://www.dealmetic.com/product.asp?ID=RC03175 the prices are very reasonable even better than the HK Turnigy Nanotechs, Im going to give them a try...I can get 2 of these for about the same I was paying for just one 6S....worth checking out anyways.... DJTunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf Dragboat
Bulkhead fittings installed, Im running dual water lines and have installed one discharge on each side so I can easily see water flow from each..Tunnels-PS295. Cats-H&M M1 Supercat Daytona rivercat. Monos-DF Cyberstorm HiTech 29. Hydros- Ms K Vac-U-Pickle Custom built 37" shovel 10th scale converted to FE Shadow. Rigger-H&M Evo II. AQ Harbortug recovery boat. Build in progress 37" cf Dragboat
