Carbone Fibre Genesis (My First Build)
  • Aaron Johnson
    • 49
    Hey Guys,
    What a great forum you have going on here, I have been lurking for about a month but have not actively contributed too much.
    I was bitten by the electric RC boat bug about 6-8 weeks ago, although I have been into RC for many years, playing with buggies, drifters, tourers, F1's, scalers and heli's etc.
    I should really grow up one day! Since I have been on the boat fad, then I have accumulated a TFL genesis and a TFL F3 Sprint Tunnel.
    Both have been heavily modified with all of the go fast bits and re-enforcements required to actually go fast without breaking crap. (I have broken alot of crap)
    I've been enjoying the genesis a lot so I decided to order myself a carbon fibre bare hull to embark on my first build. It ended up being pretty cheap as TFL stuffed up and supplied me one with a white gel coat top, I didn't like it at first but it has grown on me a lot.
    Here are a few photos of my progress thus far, please feel free to post any constructive criticism.
    • Carbon fibre genesis bare hull.
    • Carbon fibre motor mount for 40mm motor
    • Alloy servo mount
    • Alloy T bar.
    • Offset rudder setup.
    • Dual pickup rudder
    • Complete 3/16 drive line, one piece flex cable
    • TP 1600kv 4060 Motor
    • Swordfish 200a 6-8S ESC
    Here is the hull in its bare form, I decided to stick a RCBB sticker on there as I buy all of my hard parts from them. The owners service is the best I have encountered in years of shopping online.
    Marking up and drilling the holes for the strut!
    A make shift backing plate that I installed inside the hull to mount the strut.
    I spent a lot of time marking up the motor mount to get it perfectly square.
    Getting there, motor mount and strut installed.
    A couple of dual water inlets to feed from the dual pickup rudder.
  • Aaron Johnson
    • 49
    Installed a water outlet on each side of the hull, again took a little while lining them up perfectly haha
    I ended up taking the offset rudder off the fibre glass genesis, i'm not sure if I will run it on this build yet..
    Starting to take shape!
    Every battery mount on the market seemed to be 56mm wide, too fat for the genesis... So I embarked on building my own.
    I'm really happy with them, a layer of non slip rubber over the top and they will work just fine. Quite light at only 50grams each.
    All glued in, servo and stuffing tube to go!
    • Fella1340
      • May 2013
      • 1025
      Looking good. I really like the Genesis hull, I only have the HK version but its great for the money. Looking forward to seeing this through to completion and hearing feedback from you! Jeff
      • rickwess
        • Apr 2013
        • 777
        I like the look. Is the top half of the hull fibreglass?
        • Fella1340
          • May 2013
          • 1025
          It does look sharp with the black bottom and white gel coat top. A few decals and its done!
          • Aaron Johnson
            • 49
            The whole boat is carbon fibre, the top half has simply been painted with white gel coat. :)
            Thanks man :) I'll probably just end up throwing a number on her, unless I come across some real nice decals :)
            • Aaron Johnson
              • 49
              Soldered up the motor and have started working on the fitment, will most likely drop the shaft in tomorrow.
              • nemz305
                • Jul 2013
                • 42
                looking nice i been wanting to build a carbon genesis......i have the fiberglass version with a leopard 4082 1600kv seaking 180 amp on a x450 prop with the 3/16 shaft my top is 65mph buth runs about 61 all the time.. i run the same offset rudder but i think it creates alot of drag and slows me down but definitely helps the handling.
                • Aaron Johnson
                  • 49
                  Drilled the hole for the stuffing tube, I really like the T bar concept!
                  All lined up and ready to secure, for once I managed to bend the stuffing tube perfect first go
                  Epoxy putty to seal up the gaps.
                  Strut end of the stuffing tube
                  • Aaron Johnson
                    • 49
                    Servo mount all ready to go
                    Bad shot of the rear end fully assembled.
                    Just before she went on her maiden run!
                    I will take some more photos of the completed setup when its not so hot, it's been about 40 °C over the past three days. Thats about 104 °F for the yanks!
                    The boat runs very very smooth and the power in quite insane, I clocked it at 100kmph / 62 mph with a 46mm prop with no timing in the motor and about 3/4 throttle.
                    To go faster I am going to have to wait for a day when the water is glass, most likely need to tinker with the prop/strut position a bit as well to see max speed.
                    Very very happy with it all. It's cost me around $700 which is fairly impressive given the motor / esc combo takes up about $260 of that.
                    • Fella1340
                      • May 2013
                      • 1025
                      It turned out great. You should be q happy guy! The plate holding the thru hull nipples is a real nice touch. Did you make the plate your self? If not i.would love to find oiut where to.get ir. Thanks, jefr
                      • olwarbirds
                        Magic Smoke Wizard
                        • Oct 2012
                        • 1194
                        nicely done...hope you get to post some vids...ive been looking at the same hull and using a similiar power setup...DJ
                        • Aaron Johnson
                          • 49
                          That part is available for sale from RCBoatBitz here in Australia, good service and reasonable pricing!
                          Here is a link:
                          I will take some video of this beast in the next day or so, the power that it has is crazy. I have tried a few different 3660 and 4074 1600kv motors in my fibre glass genesis but nothing compares to this TP motor!
                          I just need to dial in the strut position, she is running a little bit wet. But I dont mind it actually because it is hell stable and easily getting into the 105kmph mark with a 4614 prop.
                          • Aaron Johnson
                            • 49
                            Another important update is the fact that I have given up on Swordfish ESC's, both of the 220amp units I received were pretty much DOA. I will never buy another of them.
                            However, I did manage to get my hands onto a RCBB 200amp ESC from RCBoatBitz. This ESC is atleast 30% bigger in physical size, the cap banks are larger and it comes with 8 gauge wire all round.
                            The ESC has so many different programming options, nothing like I have ever seen before. It performs like an absolute beast! I was using a Turnigy 180amp ESC on this for a couple of runs whilst waiting for the RCBB unit.
                            The RCBB unit has atleast double the power of the T180. I can't get past 70% throttle and the boat is hitting 105 kmph...
                            For $130AUD, I will be buying many of these speed controllers next year!
                            • olwarbirds
                              Magic Smoke Wizard
                              • Oct 2012
                              • 1194
                              Nice, those TP motors have been getting some good reviews recently. Im going to try 2 of them in my twin cat build. I hear ya on the Swordfish, never again here either. The turnigy/Hobbywing esc's are not bad we been using them alot with xtra capbanks, I agree that they are not the most efficient, but with them you at least get what you payed for ! Your new esc is a beast...looking fwd to seeing more on what your doin....Merry Xmas....DJ
