Pete's Whiplash 20 LSH
  • Shooter
    Team Mojo
    • Jun 2009
    • 2520
    #106
    Originally posted by detox View Post
    What battery capacity are you guys using? I found out that 4200mah caused boat to slow drastically after 6 laps (4200 Grim Racer lipos were puffed and hot after race). My cheap Tenergy 5000mah capacity helped, but they were also puffy and warm. Good higher capacity lipos are a must.
    No doubt you are going to see some performance degradation in that last lap or so with 4200mah. They shouldn't puff though. What prop are you using? A lot of us are running H5's and we are on the threshold of destruction, especially in the summer when the temps are up. Last year I ran 10,000mah in my LSH!! (2 4S 5000 packs in parallel). The boat was fast all 6 laps.
      • 9479
      #107
      Dude I might have to try this in my FE30
      • Shooter
        Team Mojo
        • Jun 2009
        • 2520
        #108
        First stab at the 'Dario Franchitti' Team Green scheme. I still need to do the other sponson.
        • longballlumber
          • 3119
          #109
          Looks good Pete... I just hope now that you put some stickers on it, the boat slows down...LOL
          Later,
          Ball
          • detox
            • 2310
            #110
            That looks KOOL
            When my Grimracer 4200 packs puffed I was using a m445 with a little cup added. Boat was really fast at the start, but slowed noticeably. A Tenurgy 5000 45c packed puffed also. So I switched back to the better Hyperion 5000 packs.
            Neu makes a nice 2s 6000 pack
            • Shooter
              Team Mojo
              • Jun 2009
              • 2520
              #111
              @Mike - I'll just sharpen the rudder to compensate for the speed loss!!!
              Hey, maybe that rough surface on the top will slow the air flow down creating a higher pressure on the top, thus no blow overs! I still can't believe it blew over 5 frickin feet from the finish. Woulda been a PERFECT 1200pt maiden race day!!!
              @D - I'm surprised those Grim packs puffed. I've always had very good luck with those.
              • jfrancisco892
                • Feb 2012
                • 546
                #112
                Sharpening hardware? Don't tell me you're gonna switch from the tried and true shock oil as well.
                • Shooter
                  Team Mojo
                  • Jun 2009
                  • 2520
                  #113
                  never.
                  • jfrancisco892
                    • Feb 2012
                    • 546
                    #114
                    Haha.
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2520
                      #115
                      Well, it's been a long time since I posted anything. I've done a LOT of testing and I'm really happy with this boat. I've gone through 3 or 4 turn fins, about 3 strut adjustments, and various other tweaks here and there. Speeds are up near 55mph in LSH trim. I just wish it was running like this for the big race last month, then maybe I could have competed! Oh well!
                      • ron1950
                        • 3024
                        #116
                        so was that a va craftsmen fin? just got my whip repainted and trying to figure out how to put that fin brace on the boat with out cutting into the top of the boat...guess wood screws
                          • 9479
                          #117
                          Nice!
                          Pete, what prop are you running ?
                            • 9438
                            #118
                            It would be best if there was Aluminum inside in order to tap it for bolts. Wood screws will only hold so long depending on what power you are using; LSH or P-Sport?
                            • ron1950
                              • 3024
                              #119
                              don't know whats inside as I didn't build it and there is no way get into the sponson unless I cut the top off and I wont do that :)
                                • 9438
                                #120
                                Well... If you need to drill a pilot hole for a screw to mount it anyway, just drill into the wood with a 1/16" bit and you'll know fast if there is any backer in there. Hopefully there is.
