Just starting out with an empty Titan 33 hull. Based upon answers over in the General section, I have been doing due diligence with the OSE formulas to get an initial take on motor/battery combos.
Target speed - 50 to 55 (Fluid says they start heading for the tops of pine trees at much over that)
Looking at the Leopards on the OSE site, I focused on the 3674, 4074, 4082.
Given the wattage and subsequent current draws, I believe the 3674 is too low (1000/1500 watts, 69/104 amps - not enough torque) and the 4082 a bit too "large" (2000/3500 watts, 108/189 amps - probably more than enough torque but needing a huge esc and not getting good run times) If I am mistaken - let me know
Given the 4074 ( 1500/2000 watts, 81/108 amps)as the motor of choice (or an equivalent if you have one) my question now is would you go with:
(all mph come from OSE formula with 1.4 at 42, 45, 47 props)
2 5s with 4074 at 2000 KV (loaded rpm 31450 - mph 52,55,58)
2 6s with 4074 at 1650 KV (loaded rpm 31135 - mph 51,55,57)
Given a 5000 mah battery, estimated run times with 2's is 7.4 continuous, 5.6 burst
More Questions:
Is the 4074 sufficient for this size boat (given my speed objective)
Which setup is best for heat build up? Motor, battery, esc?
Can the 4074 handle larger props(pitch/diameter) Will it handle the 1.4 42/45/47?
Given the 4074 burst wattage/amps draw (as determined above would you go with a 120 or 160 esc? What manufacturer?
Thanks in advance for the help and advice in getting this boat running in the water.
More Questions:
