Innocent Villain IV to Villain X sleeper.......
  • gsbuickman
    • Jul 2011
    • 1292
    Hello everybody,
    I had some goodie packages arrive today from Funrcboats & philshobbyshop, Thanks guys. Now I can start my Traxxas Villain sleeper X build.
    I am going to start off with my new goodies:
    Octura X447 counter rotating props set
    Octura 4mm to 3.175 prop shafts
    8 VXB stainless abec flanged bearings
    Traxxas #1581 ESC water cooler kit
    And a Traxxas #1517 deck railings, airhorn's & steering wheel set for scale appeal .
    I was playing with the boat in its stock form ie: 20T stingers, plastic 2:1 gearing, 7.2v XL-1 ESC and plastic props just to see what the oem setup would do. I ran it on twin1500mah nicd packs, and it was a wet water plowing hog that couldn't even plain out.
    I switched to a single gens ace 5000mah 40c 2s1p pack, and the difference was night & day. It jumped on plain and tried to go pretty good for an OEM setup, but that only lasted for 10 second bursts. Try as it did, after it got a good bite on the water, the props would cave and it would turn into a cavitating fool....... .
    Well that's all about to change .........
    • 7651
    Ok my friend, I'm watchin'.
    • Wetter
      • Aug 2013
      • 241
      i like the fact you can put peeps in there (action figures)
      is that the stock color?
      me to i like that boat.
      • gsbuickman
        • Jul 2011
        • 1292
        Hiya Slash , how's life with our B.C fe junkie
        • gsbuickman
          • Jul 2011
          • 1292
          Heya wetter, ya mean like this ffffftttttppppp......
          Yes it is wetter, she's as stock as they come, straight outta 1987' . They were way ahead o their time for sure......
          • gsbuickman
            • Jul 2011
            • 1292
            Alright . I just got a bit of free time & pulled this thing apart. It's in relatively good shape for being 36 years old . I did find one of the oilite bushing was split. Dammit spanky that'll defiantly leak alot ..
            Now its time to clean, dremel and get a few things changed. The stock traxxas gearing is 28t/14t 2:1 gearing, meaning the propshaft is spinning at 1/2 the speed of the motor, which really overworks the motors.
            I happen to have a pair of steel 14T pinion gears here. If there is enough room for adjustment on the motor mounts, I'll try and drill out my 14t gears & mount'em for 1:1 gearing . Now to get a few things done & see how it works .......
              • 7651
              Doin' good, building a Bling Rocket at the moment. Got a new toy shop built
              Like the Villian's, reminds me of old days. Plastic hulls only, not enough oomph for the heavy glass ones.
                • 7651
                Back in the day, I put the Hyperdrive belt drive on my Systems cat in place of the course gears. What pitch are those gears?
                • gsbuickman
                  • Jul 2011
                  • 1292
                  Thats kool Slash', glad your doing alright & keeping busy with your toys .
                  I haven't used a belt drive system in a while. I think the last one I had was on a cool ol' Tamiya frog buggy, that thing was a battery vampire. Then again that was back in the 1800mah nicad days ......
                  I believe the gears are 48 pitch, but I am planning on ordering steel gears anyway, so I am still open to pitch changes. The traxxas drive system is essentially the same setup as the Hughes gear drives everyone ran before brushless came out. I just need to regear it & turn it into an overdrive to really get the props spinning .
                  I am hoping to hear back from Bugzilla sometime soon. He's got a 24v 75a Astroflight 212d ESC for me, he's just gotta dig it out cause he moved.
                  In the meantime, I discovered I need to order a pair of outdrives cause one is all reamed out, go figure. I also need to order larger diameter 11/32 stuffing tubes, that'll accept the new 4x8x3mm bearings. I'll get an order placed & get back on this thing.
                  Meanwhile, I'll work on my rigger project a bit more. Details on that later
                  • Wetter
                    • Aug 2013
                    • 241
                    so i assume the gearing is still needed? or can it be direct drive?
                    • gsbuickman
                      • Jul 2011
                      • 1292
                      Hi Wetter ,
                      I am going to keep this one fairly simple since its just an 80's abs hull. Traxxas used a 14T / 28T gear reduction drive on these. The propshaft spins at 1/2 the speed of the motor. It will be easier to run a larger pinion gear, that brings it closer to 1:1 than trying to figure out a direct drive setup.
                      I had another villain that was running 447 props on 3s with a 75a esc and speed gems motors. It was a lot of fun. This will be an advanced model taken further
                      • Wetter
                        • Aug 2013
                        • 241
                        i have my wife's original Dawn dolls, they would look real sexy when you go post finish photos of your boat.
                        i would like a scale rig of this matter.
                        • gsbuickman
                          • Jul 2011
                          • 1292
                          Well I got one of the new octura shafts mounted on the flanged bearings in the good outdrive. The bearings are a very tight fit on these conversion shafts, but they spin free. I think when I go to mount up the new out drive, I'll toss the shaft in the freezer & heat up the bearing to expand it. The expanded bearings should slide over the frozen shrunken shaft, in theory anyway.........
                          I also got the new Jr racing z series servo mounted, as well as the railings & airhorns. Now it looks much better
                          Now I am waiting on new stuff tubes and a set of outdrives.
                          • gsbuickman
                            • Jul 2011
                            • 1292
                            Kool, I have larger 11/32 stuff tubes & outrives on the way from Tower. I also have new speed gems 2 epic motors coming from fleabay :-) .......
                            • Wetter
                              • Aug 2013
                              • 241
                              you got me lookn' for one, hard to find.
                              a few on e-bay but i am not a fan of the site myself.
                              any ways nothin' like the old days , use to use my 9.6 volt cordless Makita batts. in a kyosho mono build in the early 80's.
                              aw! the memories.
