New project: 26" monohull
  • Timmy
    • May 2013
    • 73
    This is my new project. An R2 hobbies 26" deep v impulse anti turnover hull. I bought it off revoloution store for peanuts. Unfortunantly during shipping, the prop shaft had taken a big hit and had broken the glue at the transom hole and also the wood that attaches to the servo mount. this was mainly due to a lack of cushioning in the box. Admittedly the prop shaft is exceptionally long making it very prone. They got some feedback from me anyhow! I fixed this easily with some epoxy. Shipping also was some of the fastest I have EVER seen. Now I am very impatiently waiting for the new motor, esc and servo(hk are always a bit slow). I'm going to run it with a watercooled outrunner on 3s 40-50c lipo's and see how she goes. I will post some more pics. My daughter really likes boats while my son doesn't(go figure) so I bought her a joysway warrior lite for a starter boat. that arrived yesterday, so I might slap up some out of the box pics of that as well.
    "Speeds just a matter of money, how fast do you wanna go?"
  • Timmy
    • May 2013
    • 73
    servo issue 001.jpgParts starting to arrive. I don't like the idea of using a micro servo on a boat of this size, so i'm trying to work out a way of mounting the standard one sitting next to it.
    • AustinWolv
      • Sep 2013
      • 175
      Is there enough room to just Dremel out a larger servo hole in the wood mount?
      • Timmy
        • May 2013
        • 73
        Yes, but there is not enough depth underneath the platform for this type of servo.
        • AustinWolv
          • Sep 2013
          • 175
          Roger that, hard to tell depth perception in the picture.
          Can't tell how far above the platform the steering rod is..........can the standard servo lay down with the horn pointed skyward?
          • SirBudman32
            • Aug 2011
            • 701
            You should be Ok with a micro servo in it. I have a R2 hobbies Arowana with the same rudder on it and using a micro servo in it with no problems.
            2012-11-09 14-30-47.093.jpg2012-11-09 14-31-42.640.jpg2012-11-09 14-32-27.691.jpg2012-11-09 14-33-04.759.jpg2012-11-09 14-30-22.473.jpg
            Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
              How about a low profile standard size servo?
                Nice, you made your own flood chamber, cool. You only power it with a 380 motor or is that 36mm motor?
                [ATTACH=CONFIG]107172[/ATTACH][ATTACH=CONFIG]107173[/ATTACH][ATTACH=CONFIG]107174[/ATTACH][ATTACH=CONFIG]107175[/ATTACH][ATTACH=CONFIG]107176[/ATTACH]
                  Sorry, it's the smaller Arowana.
                  • Timmy
                    • May 2013
                    • 73
                    Rc boat Bitz in my hometown had the perfect alloy mount for a standard servo lying down. Cheap too, fast shipping it's gonna be here by tomorrow. I wanted to use this servo because I bought it especially for this boat. It's a high torque, metal gear waterproof ball bearing servo. For this application it should be durable and foolproof.
                    • Timmy
                      • May 2013
                      • 73
                      AustinWolv was spot on. seems the best way to go. Damn ADS never grind a flat on the motor shaft. That be a bit annoying. Thank god for the dremel!
                      • Timmy
                        • May 2013
                        • 73
                        Ready to go, gonna have my first run today, yeeeeehaaaaw Got a proper cnc prop and small turn fins on their way too.
                        • Timmy
                          • May 2013
                          • 73
                          Ran like a dream. all good except a little Loctite needed on the coupling set screws.
                          • Timmy
                            • May 2013
                            • 73
                            What do you think of the Arowana? cool trim tabs.
                            • flraptor07
                              • Aug 2013
                              • 2451
                              To get some adjustability on the drive you might want to convert it to flex shaft and put a stinger on it. I have the R2 Hobbies Sober twin Hydro and it had the same drives on it. I converted it and it made a huge difference! BTW The build looks great!
