The "Bling Rocket" build
As always bro, she's smokin' I like it
Did you get any telemetry for comparison with the das 447 ?...
Shawn, try putting a little more hull in the water by raising the strut a bit. Should settle the chine walk.Originally posted by srislash View PostAnd then I had a pair of 3300mah 5s packs. I really think they are a bit light for the speed. Hence the 'chine'"There's nothing else I really want to do other than get up and build boats." - Mike Fiore
Also make sure the hull is balanced side to side. Being a little heavy on one side will induce chine walk...stuff you already know, just tossing it out there."There's nothing else I really want to do other than get up and build boats." - Mike Fiore
Hi Joel. I've wondered about that. I assume you mean a static balance. How do you account for the torque from the prop making the one side seem heavier? Trim tab?Originally posted by Rocstar View PostAlso make sure the hull is balanced side to side. Being a little heavy on one side will induce chine walk...stuff you already know, just tossing it out there.
It's more of Torque steer that is usually more predominant during acceleration and sometimes during let off especially with larger props. With a little practice I just use a little rudder input to keep her straight. If the prop is causing chine walk I would raise the strut or run a smaller prop. It's a balance between full tilt speed and drivability.Originally posted by rickwess View PostHi Joel. I've wondered about that. I assume you mean a static balance. How do you account for the torque from the prop making the one side seem heavier? Trim tab?"There's nothing else I really want to do other than get up and build boats." - Mike Fiore
