Lookin good Shawn
The "Bling Rocket" build
Update, Got her cleared. Did the inside too as it will help insulate the highly conductive CF. I also installed my hatch hold downs. Went bolt style with blind nuts. These are them
I drilled small holes for more bonding area on the blind nuts as they need to be epoxied in
I held the epoxied nuts in place with tape and foam backing. Then I screwed the thumb screws into the nuts to seat them while epoxy cures. Important tip here when epoxy ing nuts in, make sure you oil the threads of the bolt before threading bolt in. This will keep the epoxy from sticking to the threads. You can actually make threads in this way.
This is the installed look
image.jpgLast edited by srislash; 11-29-2013, 12:55 AM.
We have a dusting of snow here. The river and pond are frozen over now...Originally posted by srislash View PostThanks Joel. Got the weekend off so should get her back together before snow Monday.
Provided that part from Randy comes today that is.
Yep they look right at home on the boat,
I had put rubber caps on the bolt heads to give a little more grip.
And also to blend in with the boat with the right colored caps.
Did you mod the hatch tab or the slot in the hull any for strength there ?
I turfed the venter tab and I think the corners will be fine on this hull Lenny. Are they pretty thin on yours?Originally posted by lenny View PostYep they look right at home on the boat,
No the corner are very good on my two hull,
It's just the used one that was beat up before I got it.
At the hatch tab hole and deck above it and also the bottom of the hull,
I think they used it as landing craft a few time to.
pursuit hull 022.jpgpursuit hull 023.jpgpursuit hull 024.jpgpursuit hull 025.jpgLast edited by lenny; 11-29-2013, 04:36 PM.
Love it!!
Good looking boat Shawn. The thumb screws definitely let you get the hatch open quickly.
