Avanti's Armada now has a Delta Force 33"
  • tth
    • Apr 2008
    • 1600
    Pinstripes
    GOOD JOB MAN I ALSO ADDED PINSTRIPES ON MY DF29.5" I ADDED A STRIPE ALL THE WAY AROUNG THE HULL AT THE SEAM WHERE THE DECK IS JOINED. STILL UNDECIDED ON A POWERPLANT THO. I AM LEANING TOWARDS AN 8XL OR 9XL UNTIL I CAN GO BLACK. SORRY THE PIC IS SO LARGE I'M HAVING TROUBLE ON PHOTOBUCKET EDITING MY IMAGES SOMETHING WRONG WITH MY ACTIVE-X.
    • Avanti
      • 1298
      Well here is the update.
      I am getting the 7xl back from obrien
      my hydra 240 and evo25 should be in Wed.
      I just ordered my speedmaster hardware and 5.5mm bullet connectors from OSE
      (he was low on 6mm, so I will upgrade later)
      I got a bruline antenna from the local shop
      the through hull power switch came out of my TC31
      I have a water cooler from another boat
      tabs are here
      motor mount is here
      turn fins are coming
      motor is around the corner
      Am I missing anything here
      The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
      • highndry
        • 685
        receiver battery
        Boats don't win races, drivers do.
        • highndry
          • 685
          my bad. you probably wont need one until you go to 4s2p
          • Avanti
            • 1298
            I have a receiver battery
            Thanks, highndry
            • Avanti
              • 1298
              one other possible problem I forgot to mention.
              the stringers are too short for both motor mount screws.
              I have a couple ideas to remedy this, but would like to know what you guys think.
              1. backing plates with spacer in between for the top bolt.
              2. add to the stringer and glass it in.
              any other thoughts?
              • z400
                • 1333
                Im not sure what to suggest.
                but i would say which ever one is going to be the lightest, but strong enough to handle what your wanting to do.
                Z
                KBB34" Mono - Fast
                ToySport Triton- Not as fast
                • Avanti
                  • 1298
                  well after speaking with Joe Solinger I was worried about frying my new lipos from amp draw, so I just ordered a second one so I can run 4s2p for a total of 250amps
                  4s1p 5000mah 25c = 5amp x 25c = 125 amps x (2p, second battery) = 250 amps
                  I would hate to wreck something that cost so much money.
                  All my stuff should be here just in time for next club meet.
                  • Avanti
                    • 1298
                    crap I forgot the thrust bearing.
                    anybody in our club have an extra that will fit a 5mm shaft .150 flex that I can buy on the 20th
                    • hebner
                      • 655
                      Thrust Bearing
                      I have an order on the way with an extra 5mm TB, will bring it on 20th.
                      Hugh
                      • Heath M
                        • Mar 2008
                        • 865
                        I personally don't know what all the worry is about 1p setups are fine. That is all our national rules will allow and i haven't heard of anyone blowing a set of lipos yet..
                        We just had a major electric race meeting and the 3 top P mono's were 33 DF's
                        1st place ran a 1521 not sure on the wind
                        2nd ran a 1515 1Y
                        and 3rd (me ) ran a 1515 2D
                        Heath
                        Brisbane,QLD, Aussie
                        • Avanti
                          • 1298
                          thanks for the input Heath, I am just being over cautious I'm sure.
                          • highndry
                            • 685
                            John,
                            So you are going to run the 7xl on 4s2p?
                            I'm so confused..............
                            Just want to make sure the only thing you are going to cook at the next meet are the dogs.
                            • Dr. Jet
                              • 1759
                              Mmmmmm........ I love Korean barbeque!!
                              A nation of sheep breeds a government of wolves
                              • Avanti
                                • 1298
                                DF33
                                hydra 240
                                7xl
                                5000mah 25c 4s2p
                                prop??
                                where am I going wrong? I'm new to this high dollar stuff and would hate to kill it.
