50" Thunderbolt with twins
    Well lots of accelerations are going to heat air cooled motors up. Back in FighterCat days some good luck was had by installing brushless fans over or near the motors. You phase lots of air in that hull to dissipate heat. Any auto parts store should have some small fans.
    Another suggestion, run smaller props. I am running big speeds on my R42 with only 47mm props. Maybe some 50-52 mm. My gut feeling is 5214's. And two blades will be easier to turn than three, mind you the 3's will accelerate better in that water in the vid.
    • iridebikes247
      • 1669
      #77
      I think your right, the escs and packs can take more than the motors or atleast theyre running cooler. If looking for an upgrade motor I'd probably go tp 4070s 1400kv or tp 5840 1400kv. Regardless, the boat looks great.
