FOUNTAIN P1 50" / 127cm Twin Setup Real Building
  • axel
    • May 2007
    • 127
    So guys after a loot of not finished threads I decided to post one which will come to an (happx hopefully) End.
    After i found the thread here i bought the Hull.
    It said it will take 7 weeks before it arrives .
    So i was astonished that i got after 9 days a postcard from Customs that i have to declare some sruff.
    So i drove out there and it was the hull.
    It was super packed no damage at all.
    Arriving at home i immedeately pulld it out.
    Firet thing i noticed
    It was NOT gelcoated!
    I looked up the auktion wasent mentionend there : OK
    But the finish was ready for Paintjob
    So i had to do this time everything opposite
  • axel
    • May 2007
    • 127
    So i did some calls and a friend of mine said he knows a good airbrusher and i should give him a try!
    So here are the first results
    there are 3 layers
    1. paint
    2.clear
    3.clear
    on the 10th of September i will get her back
    so i still have time to think about the Setup
    Sure is
    2 Outrunners
    6S2or 3P
    Speed aim is 60ties
    so its still time till then
    Hope you like what you see so far
    Axel
    • Fella1340
      • May 2013
      • 1025
      Looking really good. I saw the same post (we chatted there), gladly to see you have moved to a build page!
      So, no gel coat. What is the finish like? Is it just primed over fiberglass? It just made me wonder if it was
      Clear gel coated. I plan on buying this hull within the next week or so. Please share all your thoughts good, bad or anything in between. Paint looks really sharp, are you basing it on a particular big offshore
      boat? What do you think of the top to bottom deck joining and the strength of the upper deck? I really
      the boat and would really appreciate any feedback you can give me! I will be following you closely on this one. Thanks a lot and enjoy your build! Jeff
      • axel
        • May 2007
        • 127
        Jeff i don´t know if it was primed direct on the glasfiber but its ready for paint.
        Yes it is too light mine will get a thick layer of CF(320g/cm) cloth (400g/cm ) total in upper and bottom deck.
        That is the Original
        I will get mine back from the airbrusher on Sept. 10th
        he is about 400miles away from me.
        Have fun watching
        Axel
        • Fella1340
          • May 2013
          • 1025
          September 10th, so long! I think we could smooth the process over a little and just give the airbrusher
          my address. He can send it COD. I think this work work out very well.....for me. Good luck and can't wait to
          see the hull. Who knows, I may have mine by then. Jeff
          • Fella1340
            • May 2013
            • 1025
            Hey Axel, I was rambling on on the other post and realized I should be talking to you here. I am
            Not. Used to this forum stuff yet! Have you worked out what you are going to run? You said you
            Had the hull delivered to Germany so I take that's where your at. Hows your pricing compare there to here?
            (I am Canadian). I have ended up on many German sites that has absolutely gorgeous hardware although
            I can't make heads or tails of what they are describing. I just wonder why we don't see more of it here.
            in a twin setup on a mono do you basically need to put the stingers side by side? I have wondered on some
            Of the scale builds I have seen with you he drives spaced so far apart how it affects performance. It seems like your leaving more hull in the water with the setup trying to surface drive. (I couldn't figure out how to word the last sentence but I hope you get it) Those thoughts made me decide to run a single and keep it simple. But you can see I have thrown the keep it simple part out the window with going adjustable trim tab/drive. Anyways, just curious as to what your planning to run. Jeff
            • axel
              • May 2007
              • 127
              Jeff i tried some of the things you want to try allready way back and sorry to say no sence in it for FE .
              We can balance a boat with the weight and that is firm! By that speed we are running you wont have a chance for adjustments.
              I know Canada ,i went as a kid to school in Montreal and Toronto !
              Up to last year i was normally 1-2 times a year in Scarborough .
              So to my twin ok i am a bit crazy too.
              It will be a twin setup first test with 2 Outrunners running on 4S3P5800 . - i just want to try.All say not possible :-)
              Here 2 videos
              1. Apache 58 with 2T600/1400 spinning 51 Graupner Props of a friend of mine. ( He bought the boat from me and took the setup i advised him)
              2. A MHZ Kiton with 2 MHZ-Scorpion 4035/1260 running on 6S2P
              So you see the setups work fine.And yes all surface drives.
              A lot of hardware i buy from Horr
              The 2 Stingers will be only 63mm apart so that i can prop up to max 60mm Prop , but will start as usual by this size with 2 51 Karbon Props.
              I hope that at the end running a 6S setup my ABC 2016/3 will work.
              But that is all way down from now.
              Axel
              • Fella1340
                • May 2013
                • 1025
                Those setups obviously work! The mhz looks like its got all the power it needs and then some, then some more! I really look forward to seeing your build. I like that your doing your own thing and the hell with what
                other people think. I am new to fe boats so I will take all the help incandescent get. I am not going
                To change y mind on power trim and tilt. I realize there will be no time for making adjustments
                when running, just not possible to do. Then there's the point that once your boat is setup well
                There is no need for making adjustments. All this is very true and and perhaps it makes no
                Sense to do but I am going to do it and make it work very well! I have been building custom
                Machinery all my life and this being my fist big boat build I wanted to do something
                different. I realize there is no place for it in racing but I like the idea of being able
                to cruze down the lake and adjust the tilt till I am puking a monster roster tail behind
                me. Or just being able to trim it till its running s loose as possible or nose it down
                In the rough.stuff. its all for s--ts and giggles! Looks like your going to have a power
                house on your hands. I just had to stop as it sunk in to what you have planned
                And I had to get a calculator. What kv are you planning to run?!
                Jeff
                • axel
                  • May 2007
                  • 127
                  Ws i said Jeff your choice and i understand, just wanted to mention it.
                  On 4S the Motors have 1970Kv with 2.7Kw output
                  On 6S 1330 - 1400 - 1260 depends wich Motor but i think i will try all 3 .
                  It won´t be a raceboat but gain is 60+ but only if it stays stable.
                  Axel
                  • Fella1340
                    • May 2013
                    • 1025
                    Hello Axel, I just received my boat. I have got to say I am very very surprised and happy with it.
                    You were right, it is ready for paint. Its nicely joined together and the seam has been filled and the
                    whole boat gone over and then odometer. I can't see anywhere other then filling the vent scoops in that
                    This requires any work at all! A little carbon fiber inside to stiffen it up and the boat will be good to go! I have surgery next week, its been moved up so I won't be starting a build thread for a couple of months, hopefully
                    Sooner. Thanks for reccomending the hull! Jeff
                    • iridebikes247
                      • 1528
                      i've been following this build i look forward to seeing it completed. good luck with your back surgery man.
                      • Fella1340
                        • May 2013
                        • 1025
                        Hey Axel, what's happening with the build? I was looking forward to seeing things progress as I recover. Lets see some action!
                        • axel
                          • May 2007
                          • 127
                          He Jeff the painter couldn´t hold that date for pickup,because his kid was sick.
                          so now is the new date the 13th this month. He is 350 miles distance from me and i don´t want to post the boat.
                          • Fella1340
                            • May 2013
                            • 1025
                            No worries, just thought i would check in.
                            • Alfa Spirit
                              • 2131
                              Originally posted by axel View Post
                              Here 2 videos
                              Axel
                              Hi,
                              The Apache need more power, I mean more voltage 10S or 12S and 800kV motors. The KITON is much better, the boat is nervous, SCORPION are very good motors
                              I' ve got the same hull
                              I will run 10S and 2 x 4092-930kV motors
                              The rudder is an Arrow Shark center mount with T bracket and 2 arms for linkage. Stingers are HOR 1/4" with flex stepped down to 3/16".
                              3/16" stingers can work but they are really too small looking to the scale of this deep vee.
